National Rail services with Staff Nominee Oyster
Daniel
5 Oct 2005
Only section 1 of that document applies to you with a staff nominee card. Technically the document is incorrect as you don't have A PRIV, but the routes in section 1 are the same nonetheless. Section 2 does not apply to you.
ssray
3 Sep 2011
With a no priv/staff pass without the NR double arrow Virgin will not honour the euston to watford bit
Ray
matt_world2004
5 Nov 2014
Ray
They should do. As it is valid on all national rail services between Euston and Watford Junction.
Reading that document,I have a staff pass if I am travelling with a group of people can I purchase privledge rate tube tickets for my travelling party. It does not say PTAC on it.
Haywain
3 Feb 2013
If your staff pass does not say PTAC on it, it will not have the double arrow symbol and is not valid on any National Rail services (other than, perhaps, London Overground). I am not convinced that in these circumstances interavailability applies either.
87015
3 Mar 2006
GEML/WCML/SR
Staff & nominee oysters do not have either PTAC or BR arrows but are certainly valid on interavailable routes as listed in section 1 of the OP.
matt_world2004
5 Nov 2014
It opens the barriers at Marylebone so should be valid on at least one national rail route. As I used it between Marylebone and uxbridge the other day.
Mojo
7 Aug 2005
At the risk of being accused as a pedant, but just to clarify the terminology. TfL staff passes (including nominee passes) are not valid on Interavailable routes, but they are are valid on NR services listed in section 1 of the document linked to in the original post, as well as on Lorol services (and TfL Rail when they launch later in the year). Some of these are Interavailable routes, but they are not valid on all Interavailable routes (eg. Kings + to Finsbury Park is not permitted). Bus Operator (including Bus Operator nominee) passes are not valid on NR services at all, except Lorol.
ssray
3 Sep 2011
I have since 2006 been travelling from new street to euston daily(ish) and i can`t get a ticket with my staff pass from watford to new street only from euston to new street as I don`t have the `double arrow`
RJ
25 Jun 2005
Back office
There are a number of lines TfL Staff passes without a PTAC are valid on;
  • Euston to Watford Junction on London Midland and Virgin Trains
  • Marylebone to Amersham
  • Finsbury Park to Moorgate
  • West Hampstead Thameslink/Kentish Town to Elephant and Castle/London Bridge - but not to travel between West Hampstead Thameslink and Kentish Town
  • Fenchurch Street to Upminster
  • Liverpool Street to Stratford
Inter-availability is independent of this scheme, although there is some overlap.
What you say is correct for Bus Operator Oyster cards.
Deerfold
26 Nov 2009
When my sister gave me my pass, she told me there was a number of services that I can use National Rail services. I managed to find this document on the internet.
http://www.scribd.com/doc/105633052/TfL-Staff-Travel-Facilities-on-National-Rail
Is this still the case?
Thanks!
Your sister should also have been given a sheet detailing validity of the pass - this is usually on a sheet of A4 - it may be worth you asking if she has this - or can get this from work (I don't want to give you the wrong one - as other posters have said there are various versions including bus operator ones with no rail validity).
Though of course if you're only going Euston to Watford Junction it's not valid as Virgin services are pick up only from Watford Junction going north and set down only going south.
