National Express - If the first leg wasn't caught, will the ticket still be valid?
hvshe
7 Jun 2023
As titled, for a National Express coach ticket, if the first leg wasn't caught, will the ticket still be valid on the second leg?
For example, My ticket is from Heathrow Terminal 4 to Birmingham, the first leg being 205 from T4 to T2/3, and the second leg being 210. If I miss the first leg but I made up my time using other means of transportation, will the second leg still be valid?
Just in case I miss my first leg, definitely not in the process of buying a ticket ;)
Deerfold
26 Nov 2009
Of course, unless you're very early or late you can use rail & underground services between T4 and T2/3 for free anyway.
Smethwickian
9 Feb 2011
Errr, Smethwick!
You are lucky to find a booking with a connection from T4 to Central Bus Station anyway as the availability of local journeys within the airport on NX has been reduced due to some services not having a 'local' fare. Passengers are generally advised if there isn't a direct coach to the terminal they require just use the free Tube/Elizabeth Line/Bus H30 transfer from Central anyway as it would often be quicker.
TurbostarFan
8 Aug 2016
Technically not as per their conditions of carriage. However, it's worth a try as I don't see anyone having a problem with it.
