NAAR Signals
rower40
1 Jan 2008
Suggest it’s “Not Approachable At Red”. Effectively “double block “ operation.
NSEWonderer
5 Dec 2020
Pretty much above, its pretty much a distant signal that can show a Red, making the actual Signal thats truly set at danger, un approachable. Thats how I've always understood them.
Supercoss
5 Jun 2016
A few of these in London on Thameslink route
“ mid platform signals” non approachable at red to avoid train being stopped at location where it will not be fully accommodated in platform, looks just like a regular signal
BTU
13 Jan 2016
That makes perfect sense it's the distant signal that can show a red. I was missing that I kept thinking distant signal that cant show a red as in 2 aspect signalling here making the double block and Not Approachable at Red.
Thank you everyone.
Sunset route
27 Oct 2015
We’ve got distant signals on some of our bi directional signalled running lines where in the normal direction of traffic of flow the distant signals for the wrong direction bi-di will show red and can not be approached whilst showing red. But as soon as the bi directional signalling is used will trains now travelling counter to normal flow and to approach them the, they behave like normal distant signals with the red aspect disengaged. The reason for this was during normal working was to reduce the risk of driver reading across errors.
Tester
5 Jul 2020
Watford
I can follow the logic of that.
For context, where is this, please.
Supercoss
5 Jun 2016
Down Moorgate
TWH3007 TWH3011 TWH3015 TWH3019
Up Moorgate
TWH3008 TWH3014 TWH3018
so all underground in Thameslink Core
entrance to a track circuit block section.
Supercoss
5 Jun 2016
Consider them as distant signals on a Bi Directional line But due to signal sighting issues , so they are not mistaken or read through risk ,they show red when Bi Di working not in use
This is all well and good until someone decided to do a bit of parallel running through the core , two northbound trains running next to each other …….!
Port Road
27 Sep 2025
Interesting. But the signal in the photo is plated as an automatic [stop] signal?
milooo
3 Dec 2024
Stevenage
Doesn't this kind of signal also exist in the Trent valley especially on the approach to junctions and rugby?
