My idea for reconfiguration at Sheffield station
Donny Dave
9 Jul 2005
Doncaster
Would it be worthwhile for Network Rail to take a long possession at Sheffield in order to reconfigure the North of the station? There are 2 disused turnback sidings which take up room, limiting what can be done currently.
GardenRail
26 Mar 2023
Not sure what it would achieve. There's still the Nunnery to contend with. Regards the two Sidings, the Centre Siding is used many times per day. The Down Siding alongside the road, would be useful, but drivers won't use it because there is no walking route. And it's been out of use since the freight train derailed. But there's no reason to reinstate it because of the walking route issue.
Northampton
Not worth it with NPR, HS services (of some form) and MML electrification potentially looking for quite major changes not a lot later.
Helvellyn
28 Aug 2009
I mean with a large pot of money found down the back of the sofa you'd look to rebuild with eight through platforms, allowing permissive working to use them as A/B, ditch the through roads and relocate stock stabling away from the station.
As it stands before things like electrification if other modifications would have a business case that stacked up (e.g. eleviate XXX delay minutes at a cost of Y versus the change costs of Z) then it'd have been done or in a plan.
Meerkat
14 Jul 2018
I assume major rebuilding will be restricted by the heritage status of the buildings?
Grumpy
8 Nov 2010
Why would you need eight through platforms? There are only about four through trains/hour in each direction. Other stations handle more through trains with only 2 through platforms. Although I am not suggesting only 2 be provided.
Most trains are terminating, not through. Perhaps what is needed is more long bay platforms physically linked to the entrance thus allowing most passengers to avoid the hassle and delay of having to use the footbridge
Meerkat
14 Jul 2018
May as well have long through platforms if the signalling can allow them to be used for simultaneous terminating/reversing trains from both directions - more flexibility.
YorksLad12
5 Feb 2020
Something that crossed my mind was that P7 was being used for EMR services yesterday. It might be being used regularly, I only noticed yesterday during the perturbation caused by the points failure near Swinton; I usually see them on P2 or P5. Using P7 means you could then use P6 or P8 for the other EMR service, and you'd be able to create something for EMR passengers at that end of the station. A bit like Leeds mostly using P6 or P8 for LNER services, with an LNER information point close by. Unfortunately, it doesn't quite time right to have the Liverpool-Norwich services use P7 at the same time, to improve platform occupancy, but you could still make that area an 'EMR hub'.
That would free up one of the through lines. P2 can have trains approach from either side, although I haven't spotted a centre signal for traffic entering from the north.
Grumpy
8 Nov 2010
Yes but with only 4 through trains/hour in each direction why would you need more than, say, three or four through platforms?
The present layout requires nearly all passengers to use the footbridge, lugging their baggage etc. Passenger convenience should be more important than unnecessary operational "nice to haves"
Northampton
It's also passenger convenience to be able to keep the service running though, which if you limited the number of through platforms available would be harder. And having bays potentially would bring available platform lengths down, whereas with long through platforms and permissive working you can be more flexible in that regard.
Thats now though, things can change.
Meerkat
14 Jul 2018
Maybe there aren’t many through services because there aren’t enough through platforms…..
61653 HTAFC
18 Dec 2012
If we're talking about what we'd do if we had the magic money sofa (similar to the magic money tree), buildings can be dismantled and moved. Just look at what's happening at Huddersfield with the building on the island platform.
Meerkat
14 Jul 2018
That was a wooden building, not a sizeable stone one!
simonsays
27 Jan 2024
Uk
Rebuild Sheffield station using the space taken up by the massive roundabout, if money is no object.
The terminating platforms likely have to be in the middle of the layout to eliminate crossing moves, which means bay platforms will still have passengers using a footbridge.
Providing escalators on the platforms would render it a non issue in any case, whilst providing through platforms would eliminate operational restrictions and allow the provision of a better service, more reliably.
A uniform, or near uniform, layout of 300m class platforms would enable maximum flexibility and service improvements in the future.
61653 HTAFC
18 Dec 2012
Stone buildings have been dismantled piece by piece and reassembled too... including, famously, a bridge which was moved from London to Arizona.
The main building wouldn't need moving anyway, unless you were going to significantly widen the station footprint. Just the ones on the island platforms.
What might complicate things is the River Sheaf running underneath the station.
Northampton
Stone buildings have also been encased in framing and moved as complete structures before, or mounted on skids or similar and slid to new positions.
However I think it can safely be assumed that the money or poltical will to do anything significant with the platform structures wont be there, so the practicalities of how or whether you can demolish the buildings can be glossed over, especially if this is a 'money no object' discussion
61653 HTAFC
18 Dec 2012
Money being no object (for the sake of discussion) would mean that going to the expense of moving listed buildings can be considered... but would not (in my interpretation) mean you can ignore their listed status entirely and be permitted to demolish them... though of course if you really did find a magic money tree, you'd be able to avoid the repercussions.
It would also mean that you can throw as many resources at a problem as required, but would not permit you to defy the laws of physics.
Northampton
So I was suggesting that for the purposes of the discussion, it can reasonably be assumed that sufficient permissions and resources would be available to do whatever need be done to the platforms.
Or we could accept the platforms structures as they are and that they won't be moving or demolishing any buildings at all. It's speculative so we could go either way.
Halifaxlad
5 Apr 2018
The White Rose County
Perhaps most trains should head through rather than terminate ?
There is a desire for a direct Bradford - Sheffield service! Perhaps this could be an existing service extended from Sheffield terminating at Bradford instead ?
Perhaps some other services could be extended to York to give a regular hourly direct service ?
York has many platforms and plenty of disused ones too, both North & South!
Topological
20 Feb 2023
Swansea
As both are north of Sheffield, you would only be extending terminating services from the south. That means the Northern Hope Valley train, or the London trains. Highly unlikely London gets extended given the order for 810s is only just about big enough for the current service. The Liverpool - Nottingham (Norwich) is like a terminating train, but that reverses to go out and would need splitting to run through.
More use is pushing the terminating trains from Leeds*/Doncaster*/Lincoln*/Huddersfield* south, but then where to? There are not a lot of options.
A system which allows ample space for short DMUs to reverse is fine, most of these services would never go above 5-car.
* Used here to indicate trains from that direction.
Northampton
Nice idea, although limited capacity on approaches is a constraint (although being looked at for NPR AIUI).
The easiest train to extend would be the Penistone line train but that'll be a much slower journey time than changing at Leeds. Or you'd be extending something terminating at Leeds from Sheffield. It's safe to assume that anything currently going to Leeds won't be diverted away from there.
Isn't Sheffield-York served by a regular hourly service by XC (temporary timetable notwithstanding)?
IIRC York has 2 platform faces disused at the South end (behind platform 1, so marginally more awkward side for anything direct to Sheffield) and 2 platform faces disused at the North end (the one next to 8 and the Examination siding next to 2, which can only access the Scarborough Line). York's platforms are busy enough that NR looked at adding two additional through platforms in one of it's long-term studies. There may have been further Scarborough line platforms behind the examination siding, not sure as the car park obscures it. There's not a lot of room at York to just chuck trains at it, as can be seen on RTT if you look either at how quickly disruption compounds itself, or at how many alterations get made for specials/amended traffic.
Topological
20 Feb 2023
Swansea
Do you mean seating capacity when you say 'big enough' ?
Yes
Many London trains will be 5-car as a result of the number of units being "just enough".
There are more seats on an 810 than on the Meridians, but the Meridians are suffering from overcrowding so the 7-car Meridian is the more relevant benchmark. On that the 810 just about matches (see the 810 thread for the numbers).
Requiring extra diagrams for the 810s would not seem like the best idea, especially for routes currently served by trains a lot smaller than an 810.
So we are really just left with the Hope Valley train as a terminating service coming in from the Southern approach to Sheffield.
YorksLad12
5 Feb 2020
Had to do the Sheffield Shuffle twice this evening.
Arrived to see that the 1715 stopper to Leeds via Rotherham was still in 1b, meaning that the 1721 XC would probably move to P2. Which was duly announced; I was ahead of the game (and other passengers!) on that one.
The 1718 semi-fast was still on 2b. Instead of leaving right time, it waited... while the stopper cleared 1b. "They wouldn't..." I thought.
Yes. They would. Over the bridge we traipsed again to P1 for the XC service, which had been sat sitting for five minutes outside the station.
If there was an extra north-facing bay, the Northern stopper could have started from there. But there isn't so it didn't, and lots of passengers had to move instead. Fine if you're travelling light like me, less helpful if you're elderly, infirm, with luggage or wrangling children.
Grumpy
8 Nov 2010
Indeed. Given a sensible design with more North and South bays with level access to the entrance, the only passengers needing to use the footbridge should be from/to southbound through trains. Most terminating trains are only 2 car DMU's. Even the St. P trains are predominately only 5 car
I'm not sure how feasible it would be to provide bays with level access to the entrance.
On the other hand, it seems the problem here would be solved by simply not announcing a platform change to then undo it.
Northampton
Trains are likely to get longer in the future though, and putting all bays on the entrance side forces conflicts between arriving and departing trains.
