My idea for NMT to be replaced by a Cl800
MonsooN
30 Mar 2016
Houghton le Spring
I saw the Network Rail "Banana train" as I was heading out of Bristol TM last week. Will that also change to a Class 800 or will it remain an HST as it's not for passengers?
Master29
19 Feb 2015
In time there will probably be a NR class 800 in yellow proudly nicknamed the Banuma, Aznana , flying IEP or something similar
Probably remain an HST, there is a long tradition of using old passenger stock as departmental vehicles. There are some custom builds like the Sprinter derivative, but there's also a converted 313, and Merseyrail used to use the 501 sandwich (a 73 sandwiched between 2 Class 501 driving trailers) and the complete 2-car unit, as well as Mk1 and Mk2 coaches.
D365
29 Jun 2012
Where would a departmental 800 be sourced from?
Harbornite
7 May 2016
What would the point of that be? If anything, it would seem more logical for NR to take on some available coaches or power cars.
broadgage
11 Aug 2012
Somerset
I expect it to remain an HST for many years, indeed it might one day be the last HST still running on the national network. The "banana train" is a go (almost) anywhere train and is most unlikely to be replaced with something that can only operate on limited routes.
Furthermore the departmental train has had numerous and presumably costly internal alterations to fit it out for the specialist work undertaken, why replicate all that on a new and very expensive train.
bonzawe
30 May 2014
They could, you know, buy one...
Japan spends the money to have purpose built test trains
From Wikipedia, the free encyclopedia
JR Central's Class 923 "Doctor Yellow" set T4 on the Sanyo Shinkansen, March 2010
Doctor Yellow (ドクターイエロー) is the nickname for the high-speed test trains that are used on the Japanese Shinkansen ("Bullet Train") dedicated express passenger train routes. The trains have special equipment on board to monitor the condition of the track and overhead wire, including special instrumented bogies and observation blisters.[1]
https://en.wikipedia.org/wiki/Doctor_Yellow
jopsuk
13 May 2008
So that's one each for the Shinkansen operations of JR East, JR West and JR Central. Seems reasonable. Non bullet-train based trains aren't an option, as the "classic" network in Japan has a different track gauge. SNCF have IRIS 320 for their network and HS1, modified from a withdrawn TGV Réseau. HS2 might see the GB network needing a new-build High Speed recording train? DB have ICE S, cobbled together from old power cars and carriages.
An 800-based test train would (currently) be less capable than the New Measurement Train. The NMT can operate over all lines it needs to, with the only restriction being that it can't do EPS tilting speeds on the West Coast Main Line. Network Rail doesn't seem to consider this to be an issue that it needs to address, and obviously the AT300 series would not address it anyway.
If the reliability of the NMT is fine, then Network Rail won't want to spend money on a new train that has clearance issues.
Do the 800s have, as with some recent EMUs (eg Class 379), track and OHL recording cameras mounted on them anyway?
Marklund
18 Nov 2010
Absolutely.
The question of where NR would get one from, as often happens, was as a dismissive reply.
It's fairly obvious where NR could get one from.
The bigger (and more relevant) question would be why NR would get one.
gsnedders
6 Sep 2015
Given the lack of any UIC GB gauge connection from HS1 to HS2, hiring IRIS 320 would seem out of the question, hence I presume either it'll have to be done by the NMT or some new train (you might get away with converting some existing ETCS-capable high-speed train, depending on if it being fully captive would work).
Mordac
5 Mar 2016
Just use a 373? Better than have it go to scrap.
61653 HTAFC
18 Dec 2012
Painting it yellow just makes it look even more like a duck...
DarloRich
Fenny Stratford
No. at least not for a long time.
Also what would be the point of spending all that money to replace something that works perfectly well?
Is that the best use of tax payers money.............................
Is the correct answer!
ash39
8 Feb 2012
Worst thread I've seen pop up for a long time. Seriously?
J-2739
30 Jul 2016
@ash39
Tbf, it's not really the OPs fault, this was split from the original class 800 thread, but a note hasn't been put down yet.
Marklund
18 Nov 2010
If you're going to quote me, quote what I posted later, and in context, thanks.
Oh, and over use of ellipsis doesn't make your points any more impressive...
43096
23 Nov 2015
The NMT is on long-term lease to NR so not being replaced any time soon.
Why you would take an AT300 or whatever is beyond me. The HST has a very wide route clearance whereas the ****achi stuff doesn't. 26m vehicles would not be easy to clear over the network.
cjmillsnun
13 Feb 2011
The other thing with the NMT is there is going to be a glut of spare parts available soon.
D365
29 Jun 2012
As this discussion isn't relating to the Class 800 testing or the GWR rollout.
Suraggu
23 Oct 2013
The Far North
Your idea is pretty pointless, a one off build? Thats going to be extremely expensive.
MonsooN
30 Mar 2016
Houghton le Spring
It was just a question that I posted in the main 800 thread. I never intended it to become a thread on its own. And I don't have an "idea." That was just put in the title the moderator used.
The question has been answered to my satisfaction.
1 Mar 2016
Could the acronyms/abbreviations please be translated into plain English?
I believe it is forum policy not to use acronyms or abbreviations without first saying what they mean.
ETCS = European Train Control System
TVM = Transmission Voie-Machine (Used mainly in France).
KVB = Contrôle de Vitesse par Balises (Also used in France).
TBL = Transmissie Baken Locomotief (Used in Belgium).
As najaB mentioned these are signalling systems used in aforementioned countries amongst others.
