My idea for Glasgow to Manchester on VWC
route101
16 May 2010
Last week i travelled on the 1715 from Manchester to Glasgow and it was packed (4 car 350) i got on the first carriage and most seats had a reservation label and communters piled . Luckily i got a seat after preston . Edinburgh seems to get the 8 car 350s so i think a service at peak time from Manchester deserves better . An idea could be Virgin running Euston to Glasgow via Manchester or omitting Preston on this peak service !
Head over the the Timetables and Allocations sub-forum and do a search. You'll see this idea is raised fairly regularly.
156478
3 Aug 2013
When I had my FirstGroup staff boxes through ScotRail I avoided this train like the plague travelling from Manchester to Glasgow. Even First Class was full to bursting. Then you get to Preston and the train dies a death and the people who are actually travelling the longest on the train - to Glasgow actually get a seat!!!! There really should be a train in front of the 1700 to run as a commuter train and not a pretend Intercity service using a jumped up commuter train trying to be all things to all people.
thealexweb
5 Jan 2014
There is indeed, the 17:03 Manchester Piccadilly to Blackpool North. The two trains have the same arrival time in to Preston.
IanD
18 Sep 2011
Newport Pagnell
That would be it.
Although the 1703 would be ahead of the 1715 it would be behind a 1700.
You need to complete the current ICWC franchise consultation to get this idea registered.
https://www.gov.uk/government/consultations/future-of-intercity-west-coast-rail-franchise
Actually there's no sign at all that DfT has anything in mind for the next franchise other than tweaking the current timetable with the existing stock.
To achieve anything like you suggest, ICWC would need more stock, something the DfT keeps on avoiding (because it is looking ahead to HS2).
To get current VT services you can always go from Manchester via Warrington, Wigan or Preston on VT & Connections fares, or walk-up fares (SVR etc).
It's only TPE Advances which restrict you to their 350s.
There is a VT-only fare, but you could only do that via Crewe; however no trains are offered as far as I can see.
Another thought is that most WCML tickets to Edinburgh are valid via Glasgow (but not the other way round), so you could get VT to Glasgow and reach Edinburgh on SR/XC.
Bungle965
Buses & Coaches
2 Jul 2014
Calder Valley
I wish! There was a single 185 working the return Manchester Victoria to Edinburgh service which only died down Northbound at Haymarket!
That would have been because the service started at Manchester Victoria rather than Piccadilly, for some reason TPE use both 350 and 185`s when they start and terminate at Manchester Victoria.
Sam
Ianno87
3 May 2015
Sam
Presumably, because the route to/via Piccadilly is blocked, no electric route is available to get sufficient 350s out of Ardwick?
Clansman
4 Jan 2016
Sam
I see, but a single 185 on a peak time service across the border? Should've been 6 cars at least.
Bungle965
Buses & Coaches
2 Jul 2014
Calder Valley
Unfortunately as the previous poster said TPE were limited to what they could use due to the access to the main depot being cut off. So they would have to have to use whatever was available from a already stretched 185 fleet. I agree it is not ideal.
Sam
Class 170101
1 Mar 2014
Sam
Ah yes that does seem a viable reason.
Sam
At weekends both 185s and 350s are used in pairs on the Manchester to Scotland route simply because there aren't enough 350s when run in pairs. (NB this is regardless of engineering works at Ardwick).
