jonty14
Hi. What is the maximum number of locomotives that can work powered in multiple?
It varies, depending on the multiple working system in use.Hi. What is the maximum number of locomotives that can work powered in multiple?
Indeed, I’ve never seen any photos of triple headed 58s, but have had a 56 and 58 comboWhen the Class 58 came out the magazines seemed to make a thing about them being able to operate in 3s so i assume it was unusual at the time?
Yes they didDidn't triple head 37s used to work in the Valleys on coal /steel?
I can confirm the 2x31 and 2x37 where defently in multiple, with 1 driver, furthermore the 312 was being used as air braked rolling stock (with it's pan down).Remember there's a difference between operating in multiple (under the control of one driver) and tandem (driver for each loco). Certainly in BR days I know of a diagram for a train to be hauled by 3 locos, but only 2 were in multiple (with one driver) and the third loco had another driver (tandem).
I remember that EMUs used to carry extension brake pipes for use with locomotivesI can confirm the 2x31 and 2x37 where defently in multiple, with 1 driver, furthermore the 312 was being used as air braked rolling stock (with it's pan down).
I presume that was in order that one pair of locos be left behind at King’s Lynn to take over subsequent return trains. As I recall the headshunt in the platform at Lynn only had room for one loco so running pairs around would have been a faff.I have had 2x31 + 2x37 hauling a 4car 312 on the Cambridge - Kings Lynn Gala Day
Indeed. Although that probably only happened on EMUs with 'normal' couplings i.e not tightlock etc.I remember that EMUs used to carry extension brake pipes for use with locomotives
Actually it was the reverse !I presume that was in order that one pair of locos be left behind at King’s Lynn to take over subsequent return trains. As I recall the headshunt in the platform at Lynn only had room for one loco so running pairs around would have been a faff.
The whole day was quite something for local enthusiasts, which I was at the time. Weren’t there class 73 hauled trips on the St Ives branch as well?
But where they all under power ?I have seen videos of 10x class 66s coupled together
And 8x class 73s
I've seen 6-8 Class 66s running in a consist but I presume most are DIT?
There are also limits to loco convoys on some routes due to the excessive weight that may result on bridges etc. This is why the redundant Greater Anglia class 90s were transferred away from Norwich in batches of five (one hauling and four dead).For electric locos, I think power supply load in also a factor, but I could be talking rubbish
General Motors recommend a maximum of 6 locos in multiple.
KCS and others used to run 8 F7's in MU
