ryan125hst
How do electric locomotives/multiple units that except multiple voltages work?
I know that, in the UK, DC trains used to use resistance control from 750v DC, with trains that run on 25kv AC stepping the power down using a transformer and rectifying it to DC before the resistors. I also know that modern trains use inverters to power three phase motors.
I know that dual voltage trains in the UK (750v DC and 25kv AC) will step down/rectify the current to 750v DC and then send it to the DC bus that is used when the train is on DC. is this correct?
I wondered how some trains in Europe, such as the TGV, can operate on four voltages: 1.5kv DC, 3kv DC, 15kv AC 16 2/3 hz and 25kv AC 50 hz. AC power can be transformed to a lower voltage and the different frequency problem will be solved with the rectifier. What about the DC voltages? Can the DC bus be at different voltages and the equipment designed to work at any of these, or are they converted to a single voltage? I have seen on the Velaro specifications pages (see Wikipedia) a mention of inductors. What do they do? Are they something to do with this problem?
