Much improved service at Bolton
1 Jan 2013
Yesterday (23/07/2024) an almost 100% service from Bolton Station was only marred by the 21:31 service to Wigan being cancelled by Train Staff issues from Manchester Victoria. "This service was cancelled between Manchester Victoria and Wigan North Western due to an issue with the train crew (TH)".
A great improvement on past regular cancellations on Manchester Airport to Blackpool and Stalybridge to Southport services.
Bovverboy
1 Dec 2013
RTT says that a total of 25 scheduled departures from Bolton were cancelled yesterday. The difference with the 2131 being that it was cancelled on the day, the rest were cancelled by the night before. That doesn't include three journeys which were substituted by bus, reason not known.
Leyland Bus
20 May 2021
York
I was going to say, I travel to and from there every week day and there was a cancelled Rochdale on the board around 5pm and I'm sure another one too... Other trains were marginally late but nothing horrific.
td97
26 Jul 2017
Ontimetrains lists Bolton as a bottom 100 station in terms of performance over the last 12 weeks. 2623 out of 2631.
Leyland Bus
20 May 2021
York
This evening: 17.21 Man Airport cancelled, a Southport train after that cancelled too... it's regular as clockwork so it's no wonder...
Horizon22
Jobs & Careers
8 Sep 2019
Bolton is ranked worst out of the busiest 500 stations! It couldn’t be anything further from the OP’s claims!
td97
26 Jul 2017
It's easy to build a picture of the worst routes by reliability
Kearsley/Farnworth/Moses Gate are due to the Southport to Stalybridge services. Interesting that the peak calls from Clitheroe/Blackburn services marginally pull up Moses Gate and Farnworth compared to Kearsley.
Ince & Elton is due to the daily cancelled Ellesmere Port service.
Blackrod/Adlington is from Manchester to Blackpool North unreliability.
Trackman
28 Feb 2013
Lewisham
Ah, so the Clitheroe peaks dont stop at Kearsley?
Seems a bit odd, I thought anything that stopped at Moses gate would call at Farnworth and Kearsley too.
td97
26 Jul 2017
In the morning
2J21 and 2J23 call at Moses Gate only. 2J22 calls at Farnworth only.
In the evening
2N52 and 2B81 call at Farnworth only
The 2J23 and 2B81 calls enable the Southport service to call at Clifton instead.
Trackman
28 Feb 2013
Lewisham
In the morning
In the evening
All makes sense now. Thanks. Capacity must be obviously tight then.
sportzbar
11 May 2014
The services from Southport- Stalybridge regularly get held at Lostock Jct for late running Blackpool-Airport stopping services which themselves are usually 2-3 mins late at Lostock due to delays crossing at Euxton Junction. The Stalybridge service is usually on time until Lostock Jct. After that it's normally 3-4 mins late leaving Bolton and then stops at Moses Gate, Farnworth and Kearsley, but makes up time by Salford Crescent.
Going the other way at Salford Crescent it's the same issue waiting for the Blackpool service threading it's way through Piccadilly, Oxford Road and Deansgate. Usually 2 mins late here but can arrive at Bolton on time.
