MSTS Installation Problems
Darandio
24 Feb 2007
On trying to install MSTS on my new system it wont pass 54% and displays a message stating that there was a disk error while writing the JP1Kitami.ace file.
I actually installed it on my old system last Sunday without problems so is this Vista related?
Darandio
24 Feb 2007
Nope, worked fine on Vista here. Do you have SP1 installed?
Not sure.
Have rectified it by doing a custom installation and leaving out the japanese routes but this has now caused issues with train store.
Darandio
24 Feb 2007
Trainstore needs all 6 default routes on your system - try cleaning your discs or copying them to HD and installing that way.
Ok mate, cheers.
If all else fails I will get another copy, its only £4.99
Meld
27 Apr 2007
Those that need to know - KNOW!!!
thinking about this a little more - 54% suggests that both discs are ok as Disc1 on;y pus 27% onto your system.
1 - Run the Uninstall program from the CD
2 - Check for any residual Train Simulator folders - if they are there delete and empty recycle bin
3 - Restart PC not log off and back on. then try installing again remember to give MSTS full admin rights
may do the trick
mbonwick
26 Oct 2006
Kendal
I guess though Meld that it may be to do with where the data corruption is on the disk.
westcoaster
4 Dec 2006
DTOS A or B
had a simular problem before, half loaded on to system then stopped and did nothing , it turned out to be my security settings stopping the program running, just a thought
