Tony Whittaker
- Joined
- 9 Nov 2017
- Messages
- 73
As a retired amateur local historian, I have been investigating a double crash/double runaway on the Midland Main LIne in Sept 1867 - you are welcome to have the writeup and use it in any way you wish. Briefly, a doubleheaded Liverpool to Birmingham cattle train ran into a stationary ballast train in Dove Holes Tunnel, killing a young girl being given a lift in the brakevan. The coupling to the locos snapped, leaving the train to run down backwards on the up line, as far as New Mills, where it collided with a Manchester-Buxton service, which just managed to start reversing and stayed on the tracks while its driver jumped off, making it the second runaway of the day. Four drovers on the cattle train died, as the cattle trucks derailed and piled up.
James Needham, driver of the pilot loco on the cattle train, testified at the inquest. As he lived in Gorton, we can surely assume he was working from Gorton shed, making him a MS&LR driver. The train had left Woodley Junction at about 4.55pm according to his testimony, though it was not mentioned whether the locos had worked through from Liverpool. They did stop at Chapel station and the second engine picked up water. No doubt several such water stops would be needed on the journey. As a livestock train, it would presumably run faster, and have higher priority, than most freight. Two locos would add to both the power and the braking needed for that.
The Midland had joined the Cheshire Lines Committee in 1866, and had also partnered with MS&LR in building the New Mills section of what would become the Midland Main Line to Manchester. Now they had direct access to Liverpool via the CLC, and were in the process of building a large freight depot on the dock road at Liverpool, which would open in 1868. So this freight flow from (likely) the docks, via CLC to New Mills, Derby and Birmingham was doubtless a growing traffic.
So I am assuming that on this cattle train, we apparently have MS&LR freight locos rather than MR, presumably 0-6-0s, double-heading over the Midland all the way to Birmingham. Perhaps next day, the same locos would have taken the empty cattletrucks back to a suitable storage siding somewhere to await another service. The locos would presumably have been one of other 0-6-0s eg the new Sacre design? (There is a lovely photo of one on Hayfield turntable in 1867). And in green livery, therefore looking very similar to MR 0-6-0s of the time, cabless and outside framed?
Please may I ask if you think these assumptions are reasonable and likely? Did MS&LR locos routinely work over the MR, as MR locos did on the MS&LR into Manchester? Or have any other observations or background on this time?
