Moving to Standard Premium part way through journey .....
mgood
5 Jun 2011
Cost of Standard Premium is £25 from Crewe but only £15 from Stafford.
With a ticket from Crewe and assuming the train stops at Stafford, if I move into SP from Stafford would I still be required to pay £25 (because my ticket is from Crewe) or only £15 as I moved into SP at Stafford ?
Thanks
I'd imagine £15 as if you'd boarded there off the LNR, however it would be very prudent to speak to the guard in advance of doing this, as otherwise they may simply not believe you haven't been there the whole time.
Flying Snail
12 Dec 2006
If the guard just finds you in SP then he will expect the Crewe fare. If you approach him first and make it clear you want to occupy SP after Stafford then I would expect most would be fine with charging you the lesser amount and if not you still have the option of staying put in standard class.
Merseysider
Fares Advisor
22 Jan 2014
Are you travelling to MKC? If so, your prices are correct.
To London, BRFares shows the fare as £25 from both Crewe and Stafford.
