Motion-sensitive platform lighting
Western Sunset
23 Dec 2014
Wimborne, Dorset
Do many stations have this? I was at Westbury last evening and as I wandered down the platform, the lighting came on as I passed along it.
Peter Mugridge
8 Apr 2010
Epsom
Ashtead in Surrey has had this for a few years now.
Not sure if Epsom has - it's difficult to get a long enough time for it to cut in without someone wandering down the platform keeping it bright.
Starmill
18 May 2012
Bolton
Yes. It helps to save energy by having the lights go into "low power mode", but when a train arrives all of the lights go back up to the specified brightness. A very large number of Southern stations have them.
jon0844
1 Feb 2009
Do you mean from off to on, or brighter? I've seen the latter at many stations, but never lights going off entirely.
alxndr
3 Apr 2015
Kemble and Swindon also. I suspect it will be a very long list!
pdeaves
14 Sep 2014
Gateway to the South West
Smart escalators are becoming more common too.
e.g. Reading. It's most disconcerting when the escalator suddenly speeds up just as you step on it. I very nearly became an incident statistic once.
Variable lighting as per this thread seems like a sensible idea; I hope the control system uses less energy than leaving the lights on full!
thenorthern
27 May 2013
Couple of stations in the East Midlands have motion sensor lighting at least for some lights at the station. Also in parts of the East Midlands I know when the line is closed overnight the lights at some stations are switched off immediately.
Sm5
21 Oct 2016
Banstead does…
I went there 130am, in the extreme wilds in the dark, creepy remote location..waiting for the NRTT 37.
on seeing it was heading out from the downs, I walked the platform in the rain to bring the lights on…
which promptly dimmed seconds before the 37 came.
I must be mad.
satisnek
5 Sep 2014
Kidderminster/Mercia Marina
Yes, I've been on a couple of stations where the platform lights 'bright up' as you approach them. Considering that they're LED lights where the difference in the already low current consumption must be negligible, are they worth it?
jon0844
1 Feb 2009
Given the number of LEDs and the increased light output, I'm sure it is very much a case of 'every little helps'.
83G/84D
28 Oct 2011
Cornwall
Some station platform lights in Cornwall used to be on a timer and went off completely about an hour after the last train of the night was due then came on again before the first one next morning.
Class172
Quizmaster
20 Mar 2011
West Country
Exeter St Davids and Taunton also have these systems. As others have said I suspect the list might be quite long.
YorksLad12
5 Feb 2020
Ah yes. Smart escalators. Great if you know how they work... which I didn't when I stayed near the Berlaymont in Brussels one time, hoiking my bag up the steps... to passed by one of the locals as he glided past me :oops:
In some places it's to keep the neighbours happy.
I'd imagine the neighbours would be bit annoyed by the light coming on, going off, coming on... It's noticeable how much light there is at a major station such as Leeds overnight, even during the Christmas shutdown. I've often wondered who the lights are for when there is literally no-one around, not even station workers. The Southern Entrance closes at 10pm but remains lit when it could at least be partly darkened or given motion-sensitive lighting.
Class172
Quizmaster
20 Mar 2011
West Country
Brussels is also where I came across smart escalators; they appeared to be very common across the metro/tram network. It seems an eminently sensible idea to me as an energy saving measure where escalator use is infrequent.
Ianno87
3 May 2015
Cambridge has some motion-activated lighting on Platform 1 and Platform 4.
satisnek
5 Sep 2014
The lights I'm talking about are those which are permanently on at a slightly reduced level and ramp up to full brightness when you approach them. But yes, I never thought about neighbours :)
SCDR_WMR
17 Dec 2017
Crewe
And in rural settings, they are good for local wildlife.
My only gripe is when they aren't working properly (kidsgrove!) - as a conductor it adds huge risk in low light mode to visibility during late night or in fog.
jon0844
1 Feb 2009
LED lights are already pretty directional, so it's more likely reflections from other surfaces causing issues for neighbours - but I'm sure any light can have filters put in if there's any unwanted glare.
I suppose lights that get brighter and then dim later might be more noticeable (given the change in brightness) but I am sure they could be set to fade more gently if there was a demand to do so.
Baxenden Bank
23 Oct 2013
A problem with this type of light is if you happen to be sat still for a while. Suddenly the lights go off and you end up sat in the dark waving your arms about to get them back on again. You might be sat reading a book waiting for the train, or as I really have encountered on more than one occasion, sat on the loo!
Class360/1
10 Feb 2021
Essex
Colchester north station has motion sensitive lighting- brightens when you walk past the sensor
Ediswan
15 Nov 2012
Stevenage
A decent system will conspicuously dim for a while before turning off. You still have to wave your arms about, but far more user-friendly than going dark without warning.
beano900
30 Jul 2013
I noticed this at Edale yesterday. Lights went up a notch when I walked along the platform.
alxndr
3 Apr 2015
Quite a few just dim, they don't go off entirely.
