most unattractive looking BR diesels
D6130
12 Jan 2021
West Yorkshire/Tuscany
Of course the class 42/43 Warships were just a scaled-down version of the DB class V200/220 diesel-hydraulic locos, to which they were mechanically virtually identical. IMHO, our Warships looked considerably better than their much more bulbous German cousins.
Sun Chariot
16 Mar 2009
Veering OT :) I always have a soft spot for the DSB (Danish state railways) MX and MY, as their nose end treatment was more easy on my eye than on the Swindon/NBL Warships.
satisnek
5 Sep 2014
Kidderminster/Mercia Marina
I'm surprised that opinions of the 'Westerns' are so polarised. For me it's a classic Misha Black design with its best attribute being the way its profile matches the Mark 1 coach (best seen with both loco and coaches in maroon).
For 'unattractive' I present the Class 37. Because it's the coolest-sounding thing that has ever moved seems to blind people to the fact that, especially today, it looks like a carbuncle from the pre-technology age. The same applies to the Class 40, of course, and Class 44/5/6 is an updated, slightly neater design.
Once we got to Class 47 (and 50 and 56), BR was seriously into 'design'. Class 58 was a backward step, in common with the EMU designs of that time.
Senex
1 Apr 2014
York
Have there been any diesel locomotive designs at all that could be called attractive, except for the Hymeks and (just possibly) the 47s? (Performance is a different matter, of course. I don't think anyone will dispute what the Deltics brought to the ECML, and I'd contend that the Peaks were much better on the MML than the 47s.)
delt1c
4 Apr 2008
Surprised the 16's havent been mentioned cab between 2 full height bonnets < ventilation grills everywhere and bogies that looked as though they came from a meccano set. Class 15's were marginally nicer but not a lot
61653 HTAFC
18 Dec 2012
I quite like the Hymeks, but a friend (who isn't quite as much of a rail-nerd as me) described them as "a 47 with dwarfism" which I now can't unsee!
Discussion of aesthetics will always have a degree of subjectivity, but I don't think there has ever been a British loco that comes close in hideousness to the vast majority of North American diesels.
Class 13. Especially the 'slave' bit.
Always thought it was odd that they weren't paired "nose to nose" with both cabs retained, so they'd be like a miniature pair of 20s. Would have offered much greater visibility in both directions.
Harpo
21 Aug 2024
Newport
Class 15 actually got plaudits for its design but then look at its parent, 10800, and maybe see why?
Meanwhile Richard Hardy’s views about ‘the plumbers nightmare’, as he described the matching internal awfulness of class 16, complete the picture!
delt1c
4 Apr 2008
They and the 15s are amongst my lengthy list on post #9 :)
Did see thew mention but wouldnt even call it functional, poor vision in both directions , but main class i was mentioning was the 16
Tetragon213
14 Oct 2024
West Midlands
Class 43 HST always looked beautiful to me. I also quite like the 50s.
Merle Haggard
20 Oct 2019
Northampton
Personally opinion, but I sort of got used too the appearance of the D600s but to me, the D6100 and D6300 locos always looked as if they were intended to have noses as well but just left them off. The flat area below the windscreens just looked un-finished. The D800s avoided this with a very simple slope. It was, I think, the case that the NBL cab was pre-fabricated aluminium alloy and the exactly same for all their diesels, with or without noses.
Another jarring, i.m.o., feature of the D6300s (but, oddly, not the D6100s) was the spoked wheels. Looked like NBL had not been following the kit assembly instructions and used the wheels from a wagon kit by mistake - as was well as forgetting to glue on the nose :).
Difficult to say whether the D6100s (in original form) looked good in green as, by the time I encountered them, the colour was usually hidden by fuel and lube.oil and coolant leaks - from the roof (exhaust and rad. overflow) and seeping through the louvres. I particularly remember D6104 which also had soot and scorch/burnt off paint above some of the vent louvres and was overall as sooty black as a Black Five.
But I did like the NBL 2s, although it might not seem so from the foregoing. In their dotage they were pretty much restricted to Cowlairs bankers and one seemed to be a bit banana shaped when viewed from the front (???D6152???) possibly as a result - probably not designed for compressive forces???
Sun Chariot
16 Mar 2009
I wonder how their visibility compared to - for example - the Ivatt 4MT and Riddles 4MT: similar sized cab windows and similar distance to the front (steam: boiler, diesel: long hood).
The NBL and BTH (and 10800) followed US GM EMD design thinking of the early 1950s. The GP7, GP9, SD7 and SD9 also had long hood and small cab windows.
Strathclyder
12 Jun 2013
Clydebank
Very reminiscent of the GM streamliners/bulldogs, which is a no-brainer given they were license built with EMD/GM internals.
Pigeon
8 Apr 2015
The front end of pilot scheme designs was constrained by the need for gangway doors, train describer discs and lamp brackets, then the later addition of headcode panels. This made it inevitable that, apart from locomotives with nose ends, their front end appearance was going to have a squashed look.
This is true, but while it explains what one might call the quantity, it doesn't let them off for the quality being so conspicuously inferior to other examples with the same constraint.
The Bullied diesels were pretty ugly too with a flat front but no centre windows.
Only ever seen them in photos, but what gets me about those is the way the curvature of the front corners makes that flat front look as if it's positively concave. I had to see some drawings before I could realise it wasn't.
Of course, with Bulleid, "make it really freaking ugly" was a mandatory unwritten part of the standard design requirements.
I agree. The German ones had an oversized bulbous front with an excessively small, dissonantly styled, angular chop-top shed glued on the top of it, looking like a part from some other machine of lesser size stuck on as a temporary measure just to get it going. Ours were neatly rounded all over and the bits below and above the windows were in much better proportion.
The Peaks could look pretty fine in their cleaner variants - strong and purposeful nose ends, bodysides that went on for ever, and just so bloody big. Just the thing to appear against the sky on top of a lowish embankment with a low sun glancing off the side of it.
D6130
12 Jan 2021
I’ve always thought that the non-gangwayed 25s looked bland and monotonous.
I agree!
The D6100s also had spoked wheels....but they were not so obvious because of the design of their Commonwealth bogies. The D6300s had a different design of bogie to accommodate their hydraulic transmission.
Greetlander
3 Mar 2018
Sydney, Australia
Class 58 - looks like a school group project gone wrong. Also not a fan of the cab end of a class 20, although the front end makes me smile so I give it a pass.
norbitonflyer
24 Mar 2020
SW London
I think I read recently that the DB versions were designed so that the engines and transmissions were interchangeable, so a Paxman engine could be changed out for an MAN, or a Voith transmission for a Mekydro, but that this had proved impossible within the more restrictive BR loading gauge, so there had to be two distinct classes - PaxmanMaybach/Mekydro (Class 42 - one had a Paxman engine) and MAN/Voith (North British). This also meant than when the MAN engines proved to be less than perfect, they couldn't be changed for Paxmans.
GatwickDepress
14 Jan 2013
Remove the bogies and underframe and the 58s could quite easily pass for a garbage scow in a 1970s BBC sci-fi programme.
DelW
15 Jan 2015
Modern ones yes, but surely not the likes of these:
(Link to an image - not mine - of EMD E-unit diesels in Santa Fe Warbonnet livery)
If only some of the early modernisation plan locos could have looked like that!
Sun Chariot
16 Mar 2009
I used to dislike the class 76/77 (originally EM1/EM2) electric locos on the Woodhead route - very boxy and square, with small porthole windows plus the unsightly scissors pantographs.
But long after their demise I found myself on an SJ intercity service Stockholm-Oslo, hauled by what looked very much like the Woodhead locos, also in black but with rounded corners that looked very smart, and was probably much more driver friendly.
The SJ designation is Rc6.
Pics (cl76 by Phil Singwell from the Wiki article):
(Sorry, just noticed the thread was about ugly diesels ;)).
Ashley Hill
8 Dec 2019
The West Country
I always thought that a pair of 76s with their pantographs near full height looked the business! Here’s a photo of a pair at Huddersfield Junction from eastbank.org
