More units for Northern
Also, which train do you prefer?
  • Total voters
    65
Philip
27 May 2007
Manchester
What is the likelihood of Northern taking on the 27 175s from next year, and is there a more realistic TOC they could go to than Northern?
Longsight could be the home depot, with smaller depots at Chestrr, Crewe and Barrow.
Some suggestion of use with East West Rail has been hypothecated on the forum as a requirement for 14 3-car 100mph units fits with the 16 3-car units available. I guess they could also be of use to GWR to replace short HSTs if not needed by EWR. DfT will have a plan.
There isn't a spare depot at Chester. Crewe and Barrow could provide servicing facilities I image.
Does Northern really need them? North East is another possible bit of Northern where the fleet size would fit fairly neatly, replacing 156s / 158s off Heaton.
However, this is all speculation. Don't also forget that they aren't reputed to be the most reliable fleet.
Philip
27 May 2007
Manchester
I thought East-West Rail trains need to be fitted with the special signalling equipment? In which case are the TfW 158s more suitable, some running in multiple?
How about Chiltern and Cross Country?
py_megapixel
5 Nov 2018
Northern England
158s for EWR have been speculated before. In reality though most relatively modern units are supposed to be capable of in-cab-signalling fitment fairly easily.
What use do they have for them?
All trains need to be fitted with the 'special signalling equipment'. The EWR requirement is for 100mph and 3-car units. The TfW 158s aren't more suitable just because they already have ETCS.
Not obvious to me how 175s would fit in to either in any sensible way.
Philip
27 May 2007
Manchester
Well it'd save the job of fitting ETCS, if 158s were used. 20 vs 30 year old units is a mute argument.
With Chiltern the 175s could replace the HSTs. Northern could find good use for them in the North West too; running the Barrow/Windermere services and replacing Sprinters on suburban services like Mid-Cheshire, Hope Valley, Clitheroe etc.
It isn't about 20 vs 30 year old units - ETCS is going to have to be fitted to everything anyway - 158s don't do 100mph or have 3 cars.
Northern already have 158s so more of those might be more useful at Northern than 175s.
py_megapixel
5 Nov 2018
Northern England
Is it though? Given these things tend to be built for 35-40 year lifespans, taking on 20 rather than 30 year old trains means twice as long before a fleet replacement.
Chiltern don't have HSTs but I assume you mean the 68-hauled sets. However, the 68s are actually newer than the 175s so in terms of emissions/efficiency and also reliability that would be a downgrade. The Mk3s despite being older aren't in a bad state internally.
The Mid Cheshire and Hope Valley are commuter routes into Manchester and Chester/Sheffield respectively. They get busy at peak times. The large vestibules will pose an issue for dwell times.
Barrow/Windermere could work though there's the issue of the Castlefield Corridor.
Wolfie
17 Aug 2010
They were purchased as an off the shelf EMU which is correct. However this CAF/Siemens product was purchased over the Electrostars (oh yes which is what a 379 is) and Junipers due to the 23m bodyshell allowing a higher capacity interior which was specified for the services they worked. So yes they were purpose built for the North West Triangle services from that point of view.
If Northern do decide that the 333’s are to be retired due to either the underframe issues (they are regularly monitored and it appears to be under control) or because they want to streamline the fleet into less classes then they will purchase 331’s as the company has already stated.
I have said it so many times, the off lease EMU’s are the leasing company’s problem. Maybe they should be looking at why relatively modern EMU’s are being sent off lease.
It is highly unlikely that HMT would authorise one penny piece on more new rolling stock for Northern.
You can easily split 158s to form 3 car sets, a number of TOCs have done it.
Yes, with a suitable gangway adapter. Is that relevant though?
EWR and Northern need some units. Logically 158s to Northern and 175s to EWR makes more sense than the other way round. However, let's wait and see what EWR have signed up to - they should be some way through the procurement process by now - perhaps the solution will surprise us.
Wolfie
17 Aug 2010
Chiltern, HST???? Do you mean 68s plus Mk3s?
LOL The Irony
29 Jul 2017
Chinatown, New York
They were actually used on peak time Mid-Cheshire Line services in FNW days. I actually think they'd make a perfect fit on the proposed semi-fasts.
py_megapixel
5 Nov 2018
Northern England
Yes - as long as said semi-fasts don't share their diagrams with the stoppers, and as long as they're actually introduced at all.
Though if the diagrams could be set up for the semi-fasts to share their diagrams with the Chester-Leeds, then that would be perfect.
Philip
27 May 2007
Manchester
There is also the question about the other two 3-car 175s and more so the eleven 2-car 175s which won't be needed by EWR; splitting a small fleet between different operators would be inefficient and not cost-effective. Northern on the other hand could probably find reasonable use for all 27. Castlefield and end-door stock might not be the problem it was thought it would be, if peak time loadings don't return.
Northeen will have to get and train staff on new DMUs before long anyway to replace the 150s and 156s - 175s would be an upgrade.
That is a decision for the leasing company though isn't it. EWR had a competition to obtain 12-14 suitable units. Angel own both the TfW 158s and the 175s. Who knows what deal Angel Trains put forward to tout their units and whether they think there is a credible chance of them fitting in better at Northern or EWR (or somewhere else)? Who knows what deal Porterbrook and Eversholt and the other companies will have put forward?
I'm not sure how the strategists at rolling stock companies plan to get their stock used, and the discussions they have with the DfT and the train operators. Angel will, no doubt, want both fleets to be used. The other point about EWR is that the requirement is only for four, potentially six years. Maybe 158s do fit better, then to the scrapyard afterwards, but they don't fit the 100mph requirement. No doubt, EWR (and Northern) and the leasing companies will have to compromise.
A lot of Northern traincrew will already know 158s. 175s bring new training requirements that 158s don't.
Halifaxlad
5 Apr 2018
The White Rose County
I'm surprised no-one has mentioned how this is all going to interact with future electrification projects which are inevitable!
First up will be Transpennine between Huddersfield and Leeds.
Then probably Leeds - Hull via Selby which would be good (capacity wise) for the 333's!
I would bring in a few 350/s to operate some of the triangle services, that could double up to 8 car in the peaks.
LOL The Irony
29 Jul 2017
Chinatown, New York
All of which are at least a decade away. If they were happening right now, you'd have to start counting the days of the 150s & 155s, but we're not at that stage.
31 Mar 2020
Tiverton Parkway Railway Station
The Idea of bringing in class 379 & class 350/2 never dies. I know it's speculative but it's not going to happen. PLENTY of reasons which have already been mentioned.
• Leasing Costs
• Costs for Training
• Additional cost for maintaining a new fleet
• Them being 20m rather than 23m per carriage which reduces flexible in terms of capacity and platforms lengths
• Northern Desiring a Uniformed Fleet
Despite these trains being homeless, you have to look at the situation from a BUSINESS and COMMUTER point of view not from a TRAIN ENTHUSIAST point of view.
More sprinters and class 331s (battery version as wel) are The option.
And more 769s.
CBlue
30 Mar 2020
East Angular
• Leasing Costs
And more 769s.
Can only concur. The average passenger couldn't give a stuff about "interesting" so long as the train turns up on time, isn't filthy, has air con just like their car... and gets them where they want to go without paying a ridiculous fare.
Purple Orange
26 Dec 2019
The North
Consistency, a good frequency and, as you say, a fair price are the main factors that us passengers want. Couldn’t care less about the type of train, or the variety of trains, whether the doors are end-doors or at thirds, as long as the train and the service provided (both on-board, online and at the station) is appropriate for the journey.
I’d also argue that most passengers don’t care about their town being connected to everywhere, but rather a strong connection to 1-3 points, from which other connections can be easily made.
Bigman
24 Feb 2011
All I need is for a train to turn up, hopefully on time, and not having to stand. I have spent too many Saturday afternoons trying to shoe-horn myself onto a rammed 142, 144 or 150/2 to get from Woodlesford to Leeds. So at the end of the day, any old 4 car stuff will do.
I'm not sure even air-con is considered essential bar for 2 days a year. Most cars don't have it (most new ones might, but cars stay on the road for 10-15 years, so most cars are not new cars), even though those who do probably quite like it.
I'm sure a clean, well-kept 319/769 would be preferred over a mucky Pacer.
Wolfie
17 Aug 2010
I'd add getting a (ideally comfortable) seat but otherwise agree.
Starmill
18 May 2012
Bolton
Air conditioning was hardly unheard of in cars in 2006, let alone 2011.
Neptune
29 May 2018
My cars have had air conditioning for the last 20 years (going back to a fairly basic fiesta) and it was hardly a new concept back then.
Indeed, but mainly as a premium, added thing, typically costing £500+ extra. Only recently has it started appearing on base models (other than premium brands) so I'd still venture that the majority of cars on the road don't have it.
It also has a tendency to fail (pipes commonly perish, for example), so a considerable number of older cars might have it but not working, as people on limited budgets don't see fixing it as a priority.
skyhigh
14 Sep 2014
8-car of anything would be a nightmare on triangle services. Most of the platforms are only long enough for a 4 car 333/331. The idea of 6 car 331s works because at least some of both units would fit on the platform at every station. With an 8 car 350 (given they're slightly shorter than 333s) you might just about fit one door of the rear/front unit on. I realise 350s have gangways, but it'll still be a nightmare making sure passengers are in the right part of the train. You'd need to lengthen pretty much every platform for that to work.
