More than one change from Birmingham?
jopsuk
13 May 2008
it was noted in the "More than one change from London?" thread that network seems to be very London-centric.
Could the same argument be made though for Birmingham? I have a hunch that the tendrils of the XC network are so widespeared that the main area that might be more than one change away is Kent- from where an Underground transfer is required to get Euston for Virgin or London Midland or Marylebone for Chiltern.
marks87
23 Jun 2010
Dundee
The Far North and Kyle lines need a change at Edinburgh/Aberdeen, then Inverness.
The WHL only needs a cross-Glasgow transfer once a week, because technically Sunday-Friday you can change at Edinburgh onto the seated portion of the sleeper.
Norman
20 Mar 2011
Addlestone changing at Reading and Virginia Water.
Chessington South Branch changing at Euston and Waterloo or Watford Junction and Clapham Junction.
dvboy
6 Sep 2011
Anywhere past Norwich.
Brighton requires 2 changes too.
northwichcat
23 Jan 2009
Northwich
Like the more than one change to London:
Stations on the Manchester Vic-Huddersfield line, Helsby-Ellesmere Port line, Eccles and stations of the Liverpool Central to Ormskirk line.
OxtedL
Quizmaster
23 Mar 2011
You can do it in one, travelling via Southampton Central, although that takes quite a bit longer than via London.
is there no connection into an XC at liskeard?
I think there might be. 11:09 Liskeard to Manchester Piccadilly?
dvboy
6 Sep 2011
My other suggestion was going to be Gatwick Airport but you could change at Reading I think.
Norman
20 Mar 2011
There are no direct trains from Gatwick Airport to Birmingham or from Brighton to Reading and haven't been for a number of years.
Ivo
8 Jan 2010
Bath (or Southend)
Most stations in Essex, apart from those on the West Anglia route, require more than one change. Some, such as those served by Walton stoppers from Colchester, require three changes outside of peak periods.
Yeovil Junction
Change at Exeter St David's or Basingstoke ;)
dvboy
6 Sep 2011
My point was if you could go to Gatwick Airport via one change at Reading, but it's not the quickest option, likewise Brighton via Southampton.
bnm
12 Oct 2009
Try getting a booking engine to sell you a ticket from Birmingham Stations to Yeovil Junction via Exeter St Davids though. Not easy when the only walk-up fares are routed either 'Salisbury not London' or '+London'.
Routeing Guide would allow the journey if there was an Any Permitted fare....
Greenback
Emeritus Moderator
9 Aug 2009
Llanelli
I don't think the intention of the OP was to limit the routes, after all you might have a Britrail pass or an ALR! :D
150222
9 Jul 2011
There's loads! Baildon, Hull to Bridlington line, Mytholmroyd, Caldervale line Todmorden to Smithy Bridge (Change at Preston before Hebden Bridge and Wigan after Rochdale), Whitby line, The wherry lines, Sutton, Blanaue festiniog, Clitheroe line, Peckham Rye, Newark to Grimsby, Barton on Humber branch, Grantham, Greenford line, Denton, Reddish South, Warrington to Manchester Oxford Rd, Ashton-under lyne, Sheerness, Petersfield, Ore, Castle Cary, Seaford, Welwyn Garden City and Yarm to name a few. :)
MidnightFlyer
16 May 2010
Caldervale line - change at Leeds
Grantham - change at Nottingham
Yarm - change at Man Picc, Leeds or York
Ashton-u-L - change at Liverpool Lime St
MidnightFlyer
16 May 2010
Don't some Bridlington terminators run ex-Sheffield too?
Blaneau - change at Llandudno Jn
Locals Warrington Ctl-Man Oxford Rd - change at Liverpool Lime St
Petersfield - change at Guildford (1tpd direct ex-BHM)
If cross-London only counts as one change then most of the others can be done too - even Seaford has peak trains to London Vic.
bnm
12 Oct 2009
Good, and well made point, Greenback. Forgive me for not considering 'go anywhere' tickets. Was looking at the more workaday options. :roll:;):)
Does seem a bit silly that there isn't an Any Permitted fare though.....
<name here>
4 Jun 2010
Crawley
The entire Southern network apart from the West Coastway stations and Gatwick via Reading.
I can't think of a way to get to anywhere on the Southeastern network either.
jopsuk
13 May 2008
Entire Southern Network? There's the East Croydon-Milton Keynes service...
dvboy
6 Sep 2011
Newark-Grimsby was mentioned above, only those beyond Lincoln as stations before the can be got to by change at Nottingham or Leicester, and Newark Northgate by change at Peterborough.
bnm
12 Oct 2009
... And Castle Cary, change at Taunton.
Again, how would that get you to Yeovil Junction? I suppose you could walk from Pen Mill... but neither of the normal (not ALR or BritRail) ticket options permit such a journey.
