More and faster trains between the Netherlands and Belgium
DanielB
27 Feb 2020
Amersfoort, NL
NS and Belgian operator NMBS will double the number of Intercity services from the Netherlands to Brussels from 16 to 32 per day. In the 2025 timetable a new, quicker service will be added. With that service passengers will see their journey times shortened by 45 minutes compared to the current timetable. NS will deploy the new ICNG-stock on this service, running at 200 km/h on the high speed line. This connection will be complemented by an IC between Rotterdam, Breda and Brussels.
The shorter journey time is possible by using faster trains, less stops and the new terminus at Amsterdam South which is closer to the high speed line than Amsterdam Central. In the near future NS and NMBS work on further details like timetables and ticket prices.
Source: https://www.nsinternational.com/nl/nieuws/sneller-en-vaker-met-de-trein-naar-belgie
Doubling the frequency makes sense in my opinion, as the current Amsterdam - Brussels service is at capacity and in desperate need of more capacity. Though this will already improve with the introduction of ICNG as this enables the option of coupling additional sets for busy trains, where the current capacity is limited by the available amount of Belgium-capable ICRmh carriages.
Especially skipping Breda by the fast service saves a lot of time as the need to reverse makes the current service very slow (I actually once managed to get off that train at Breda, buy some döner at the station concourse, and to get back on the same train with dinner)
Though only stopping at Brussels South may be inconvenient for some changes to other services. Stopping at Amsterdam South on the other hand is only an inconvenience for some connections into North Holland province and won't make that much of a difference towards Amsterdam city centre which is as easily reached by metro from Amsterdam South as it is from Amsterdam Central. Though the attractivity of the station is in need for some improvement.
Below infographic provides some more insight into the proposed services:
peterblue
25 Jun 2018
Lancashire
Interesting development. It looks like NMBS/NS are attempting to compete with the faster Thalys service by running additional services with very few stops. Skipping Breda and Brussels Airport does save a lot of time, though not too much time would be lost by serving another Brussels station closer to the city centre.
7 Jan 2009
Yes, the blue service in the map is essentially the same as the current IC/Benelux trains but cut back to Rotterdam rather than running up to A'dam CS. The yellow service will be much faster, but obvioulsy won't be able to run in the opposite 30 mins to the blue service at all times and threading trains through from Antwerpen to Brussels is already quite complicated so there may need to be reorganisation of the NMBS/SNCB timetable here? Will the trains start/arrive at Rotterdam at 30 min intervals or will be they be time to do this at Antwerpen?
JonasB
27 Dec 2016
Sweden
That's a very important point. While Amsterdam Centraal is a beautiful building where you don't mind waiting, Amsterdam Zuid is a couple of platforms in the middle of a motorway.
DanielB
27 Feb 2020
Amersfoort, NL
The motorway should be under ground eventually, though that definitely won't be ready in 2025.
Important note as well: in the new franchise as of 2025, in which this is the only international route (all others allow open access), the route is mentioned to start in "Amsterdam". So not mentioning a specific station which is the case for Rotterdam.
rvdborgt
24 Feb 2022
Leuven
The restucturing of Amsterdam Zuid and surroundings will only be ready in the late 2030s...
NMBS say the north and central stations in Brussels will also be served by the fast service from/to Amsterdam:
