Modern narrow gauge in UK
kylemore
28 Aug 2010
With most re-openings, particularly in England just "pie in the sky" is there any scope for line re-openings using narrow gauge, say metre gauge, using modern swiss equipment off the peg?
There may be a million reasons why this could'nt happen in the UK, there usually are!
Would it in reality be cheaper?
I know the biggest disadvantage would be the inability to run through trains but there must be lots of lines where this would not matter except when running enthusiast specials!
Any experts care to give their views?
MCR247
7 Nov 2008
The main reason is why? What's the point? It would just make cascading stock etc awkward. Imagine the whole network overcrowded, and there is 20 odd units sitting there waiting to be sold because they're narrow gauge and aren't needed on that line anymore? You'd be a bit annoyed wouldn't you?
jopsuk
13 May 2008
Engineering trains? The current equipment used network wide would be unable to use such a line. It would almost certainly be useless for freight as well.
Mvann
19 Mar 2010
Peterborough
As with all things, it depends on the line. If you are going to lay track on a disused trackbed, it probably isn't any cheaper. If it's a line that has part of the trackbed built on or needs major engineering works, it maybe cheaper.
MCR247
7 Nov 2008
But would it overall? Having to order special stock, engineering stock as said above etc.
As I said before, I can't find any benefits?
j0hn0
20 Jan 2009
St Albans, England
there's no reason why you couldn't have narrow gauge tram networks though, Augsburg's got one as has Nordhausen
I often wondered this. With all problems associated with the UK towns having useless transport networks, I thought that surely a narrower gauge mass transit could save a lot of costs.
It was debunked at the time though :)
Mvann
19 Mar 2010
Peterborough
There are only a couple of lines that could be viable for narrow gauge, but only because they would be seen as an extension to what's already there.
WatcherZero
25 Feb 2010
I could only see it as infrastructure for a leisure destination, e.g. Country park, theme park, park and ride shuttle.
