Modalohr piggyback wagons approved for Channel Tunnel
andyfrommk
12 Jan 2011
EUROPE: The Inter-Governmental Commission which regulates safety in the Channel Tunnel has approved the use of Modalohr piggyback wagons, Eurotunnel announced on November 21.
Corporate Video
A Modalohr train being unloaded
How likely are we to see this system in the UK bearing in mind they need special terminals?
There are videos on youtube showing it carrying the tractor units as well and a passenger carriage in the rake so I wonder if they can start up a service that came a bit further inland than Le Shuttle currently does and start an 'international motorail' (demand permitting of-course)
jopsuk
13 May 2008
presumably they can only operate on HS1 (there are now freight loops to allow fright along it I think?) and any guage-cleared spurs/connected yards. Services to Dagenham?
mbonwick
26 Oct 2006
Kendal
They sound like a more modern version of the FHA wagon, which we know weren't very sucessful...
jopsuk
13 May 2008
I've seen something similar being touted, except that rather than the custome terminal, was able to use any bit of track with wide tarmac aprons either side.
LouJ
3 Dec 2008
These wagons (or a similiar version) are in use all over Europe. Go to any European station with decent levels of freight and 1 in 3 trains is composed of this type of piggyback operation. On some routes the percentage of piggyback operation is even higher! Obviously very unsuccessful!
mbonwick
26 Oct 2006
Kendal
All very well saying their sucessful in Europe (which is true), but the question was about their use in the UK.
I was merely pointing out that previous projects in a similar vein haven't worked here.
Nym
2 Mar 2007
Somewhere, not in London
Yes, but the Intermodal we can fit in here is sucsessful, ie. Containerised freight, if these where provided as RORO for freight between North and South (it would need slow lines on HS2 to be able to do it) then I can see it working, especially if it undercuts the cost of diesel, and your drivers' breaks count while the vehicle is stationary...
jopsuk
13 May 2008
Were the FHA wagons capable of taking any given standard artic trailer, or only specificly designed ones?
LE Greys
6 Mar 2010
Hitchin
Dagenham sounds like a reasonable spot, with possible access to the M25 to allow lorries to arrive and depart easily (when it isn't a linear car park). Once again, it's regrettable we don't have the Great Central any more, Annesley would have made a good loading point. Still, is it impossible to get these things to fit through W10 loading gauge?
jopsuk
13 May 2008
I'd think the "off-the-shelf" product would be tricky- it appears much of the structure is along the side of the wagon. I think (from what I can find) the FHAs were, with the trailer on them, as wide as can be?
