MK3 Bogie Differences
XCTurbostar
13 Sep 2014
Hi all,
I'm just looking into the differences which MK3 bogies have had over the years.
If the following have technical names / differences, please share them with me :D
1. Short Swing Link - Mk3a Loco Bogie with no boxes or wires
2. Short Swing Link - Mk3 HST Bogie with Orange Box and connections - WSP?
3. Short Swing Link - Mk3 HST Bogie with two boxes and different wheel covers - G shape?
I couldn't find any pictures online of a Long Swing Link bogie - are there many of these and can you see the long swings from looking at the bogie?
If there are any I've forgotten feel free to let me know!
Thanks,
Ross
Emblematic
14 Aug 2013
Ok, in order then:
  1. Wrong side! WSP detection kit is fitted to one side of the BT10, the side where the traction rod is to the left of the spring plank. As traction rods are always on the inboard side, the WSP is on the right-hand end bogie when looking at the side of a Mk3 carriage
  2. Earlier Girling WSP detection, fitted to Mk3a LHCS and some HSTs
  3. Later BR pattern WSP fitted to Mk3b and most HSTs
As to short and long swing links, we've referred to this external post previously as a good reference. It's hard to tell in your photos as you need to see whether anything is protruding below the spring plank, and there's too much shadow. However this photo (not mine) shows the protruding bits on a LSL bogie very clearly.
XCTurbostar
13 Sep 2014
Ok, in order then:
Many thanks for the information! Very interesting.
43096
23 Nov 2015
Ok, in order then:
Not quite...
No. 1 - correct
No. 2 - the Girling WSP is the third photo. This is actually the current/latest Knorr-Bremse system, which looks similar to the later BR type. The difference is subtle in visual terms, the cables from the orange box are thinner than the BR type.
No. 3 - the original Girling type
Emblematic
14 Aug 2013
Ah yes, I've looked at the photos in the wrong order, 3 is indeed the older type! Oops!
I didn't know about the third variant, so thanks for the update.
co-tr-paul
8 Mar 2016
Helston, Cornwall
OK, just to confuse things, when fresh from works, different types have their springs painted different colours be it ted, yellow or green.. Pipework in orange and markings in white or yellow.
t_star2001uk
23 Aug 2011
The yellow springs are found under most open coaches, the green ones are a stronger spring and are usually found under the kitchen end of buffet cars..
hexagon789
2 Sep 2016
Then of course there are also the 5ft 3in BT22 bogies fitted to the Iarnród Éireann/Irish Rail Mk3s (with the exception of the Push-pull Control Cars as built (they were later fitted with BT22s) and the ex-BREL Internationals which had those iffy T4 bogies). So I suppose that as they are BT22s rather than BT10s you could include them as another type of bogie altogether asides from the guage difference.
Emblematic
14 Aug 2013
And green on sleepers...
Red ones? Not on Mk3s to my recollection. Stand to be corrected.
