BestWestern
- Joined
- 6 Feb 2011
- Messages
- 6,736
An observation about MK1 coaching stock, based mainly on looking heritage rakes stabled; it appears fairly common for corrosion to appear and open up a seam along the lower bodyside, about 10 inches or so up from the solebar. This is apparent on various vehicles to different degrees, I recall one particular coach in SR green looking as rotten as a peach. I presume this is a body/chassis mounting point hidden beneath the external bodypanelling?
It also appears that some vehicles have had the same area of the bodysides plated over, with a continuous raised plate running the full length of the coach, from the solebar up to about 5 or 6 inches up the body. I gather this is some for of repair/remedy to the above corrosion?
I'm intrigued by the maintenance of these old barges, considering their age and the fact that they remain mainline approved. Is there a certain criteria regarding thier structural condition, and a periodic testing process specifically for heritage coaches to retain their mainline exemption?
