Mixed Rail Quiz Pt. II
heart-of-wessex
11 Jun 2005
Trowbridge
Hi all,
Ok, since the first part is complete, heres a batch more to go through, modern ones this time though.
WARNING: You may need to examine questions, some are there to catch you out, but only some though!
1. On LUL, how many lines have Automatic Train Operation?
2 indeed, central and victoria
2. 'Fitted Wardrobe' is a nickname for which class?
Class 20
3. There are two sections between stations on the LUL which are the shortest distance on the network, and are the same distance. Which two sections are these and what is the distance?
1. Charing Cross - Embankment
2. what is the second one?
4. Which 3 stations on the tube have the same name but are not in the same area (ie no inter-connection walk tunnels/platforms)
5. What is the A road number which follows most of the Marches through to Hereford?
A49
6. Why is a 158 nicknamed 'Scud'?
Because of the bombs used in the gulf war were crap, this apparently lead to 158s being called this as they failed perfomance in their early days of testing
7. What type of loco is expected to use summer specials to Skeggy this summer?
47
8. Which station shares a name with a UK hit pop group?
All Saints
9. A song by Gerry Rafferty is named after which station?
Baker Street
10. 'TI' is an Allox for which depot?
Tinsley
11. Melksham is controlled by which Signalbox?
Westbury
12. How many companies have HSTs?
6 it is, when you include NR (this was one of the trick questions)
13. Is Trent box a PSB or IECC?
PSB
14. How many companies run dedicated Airport services from the capital?
4 it is, it can be easy to forget First have one!
15. ONE run services to Sheringham, is this true?
False indeed, it is now NXEA
16. How many platforms does Waterloo station have as a whole
32
17. Which 2 Cities does the Avon Binliner pick up from to go to Calvert?
Bristol and Bath
18. Explain what the code HAA means
HAA is indeed a Hopper, A is the type (4 wheel MGR), A means Air Brake
19. How many stations do AXC own?
0 when it was taken over by Virgin
20. How many routes could the FGW Sleeper take between Reading and Exeter without having to run around, top n tail or do any reverse moves? (this can included the normal 'booked' route and any usual diversionary routes)
Some are:
Exeter - Honiton - Yeovil Jct - Salisbury - Basingstoke - Reading
Exeter - Taunton - Westbury Avoider - Newbury - Reading (Also Westbury Station)
Exeter - Taunton - Bristol TM - Bath - Swindon - Reading (Also Weston super Mare loop)
Exeter - Taunton - Bristol TM - Bristol Parkway - Swindon - Reading (Also Weston super Mare loop)
THERE ARE MORE ROUTES if you can think of any more!
Good Luck,
James.
1D53
2 Apr 2006
Hi all,
Baker Street
Tinsley?
5. Great Western, East Mids, Nat Ex, Grand Central and Crosscountry.
PSB
3
16. How many platforms does Waterloo station have as a whole (International included)
21?
Was 0 under Virgin.
Good Luck,
James.
CraigS
2 Apr 2007
St Leonards on Sea
Westbury?
False because now National Express East Anglia run services to Sheringham.
24.
heart-of-wessex
11 Jun 2005
Trowbridge
JsT and Craig good answers but only some are right
12) nope it is not 5, sorry try again
14) 3? nope (have you included the one that is due to go?)
16) nope it is not 21 OR 24 platforms, think again :)
Mintona
8 Jan 2006
South West
Hi all,
0 (1 if you include DLR)
A49
47
Baker Street
Tinsley
Westbury
6 (AXC, NXEC, FGW, EMT, GC, NR)
PSB
4 (Heathrow Express, Heathrow Connect, Gatwick Express, NXEA Stansted Express)
25
Bristol and Bath Spa
It's a coal hopper
3 (via Bristol Temple Meads, Castle Cary or Honiton)
Good Luck,
James.
Daniel
5 Oct 2005
1). Currently 2, Central and Victoria, soon 3, as the Jubillee line is almost complete.
4). Wimbledon Park, Wimbledon & South Wimbledon?
heart-of-wessex
11 Jun 2005
Trowbridge
Yes indeed some more correct answers and some wrong
Mintona: HAA is a coal wagon but the question is what does HAA mean? (yes HAA does mean something, its not a random letter code)
and for 3 routes the sleeper can take? more than that, be a bit more specific, mind this trick question also means a possible route on FGW metals that it can take without reversing
Daniel: the wimbledon answer is 100& wrong, sorry. Mind the question is stations with the same name (ie no suffix or prefix differences)
Mintona
8 Jan 2006
South West
Sleeper routes:
Exeter>Honiton>Yeovil>Salisbury>Basingstoke>Reading
Exeter>Taunton>Newbury>Reading
Exeter>Taunton>Westbury station>Newbury>Reading
Exeter>Taunton>Bristol Temple Meads>Bath>Swindon>Reading (Also via Weston super Mare)
Exeter>Taunton>Bristol Temple Meads>Bristol Parkway>Swindon>Reading (Also via Weston super Mare)
heart-of-wessex
11 Jun 2005
Trowbridge
and who told you that?
Ive read everywhere about 158 scuds and in a old mag of 'Motive Power' listed the reason of a 158 being called a 'scud' as well...
16CSVT2700
4 Sep 2005
Gdansk
This was because, like the notorious scud missiles fired during the Gulf War , they would leave but nobody was sure where they would end up. Also applies to Class 153s, where you are fine until the engine cuts out.
All Saints
24 mainline. There is nothing to say LUL platforms are counted.
2-axle MGR Coal Hopper. H is the code for hopper wagons
heart-of-wessex
11 Jun 2005
Trowbridge
still wrong jamie for the waterloo thing
HAA, good, it is indeed Hopper and A is the type, but the last 'A' also means something...
Julian G
9 Jun 2005
16. 32
-19 for Domestic
-5 for White-Elephant platforms
-2 for W&C line
-2 for Bakerloo line
-2 for Northern Line
-2 for Jubilee Line
heart-of-wessex
11 Jun 2005
Trowbridge
16) Yep, well done!
3) nope
Loads of people I would have thought would know this, its a record distance as well...
James.
