323235
Hi, Is there anyone that give me a step by step guide of how to apply the minimum fare rule when issuing a ticket with the Cubic Fastis set up used by Northern Rail ticket offices?
You don't have to apply it by hand, FasTIS will automatically do so if the journey requires it.Hi, Is there anyone that give me a step by step guide of how to apply the minimum fare rule when issuing a ticket with the Cubic Fastis set up used by Northern Rail ticket offices?
yes that is the problem Yorkie.
Thanks Barry, that has answered a question mark I had
Seems to be the case that the staff at my station just don't want to issue tickets at minimum fare rather than then not pushing the correct buttons.
In cases of staff incompetence, buy ticket from the ticket machine, or board without a ticket. Rinse and repeat if necessary![]()
Is it actually possible to buy "minimum fare" tickets from the machines?
Certainly didn't seem so at Bristol Temple Meads. Or would this just becaue its a different system in use?
That's not the issue though.Several people have been to the TVM at Liverpool Central with a YP railcard in the past for a journey to Southport before 10am and complained that it was costing £12... why put the money in then?!
There's no problem there; the guard has the option to excess you the difference on your return.So it only shows the minimum fare on the machines before 10am?
Seems a bit annoying for people (like myself) who are buying a return ticket, initially travelling after 10am, but planning to return before 10am on a different day.
I can understand that it could confuse people, but surely there could be the option?
I don't see how that can annoy anyone? The excess will be the difference in price that you paid and £12 (or, if the original fare is under £12, the difference in price between the price that you paid and the non-discounted fare).
.What should the passenger do if, say, the train was leaving at 09:55, and it was cheaper to buy an un-discounted fare for say £2 to the next stop, and an £8 discounted fare from that stop to the destination, rather than the £12 and there only facility available was a ticket machine?
Buy the £2 ticket and see the guard onboard immediately.
The rules allow you to buy a ticket for part of your journey when the ticket you want can't be bought using the available facilities.
If you are unable to purchase your ticket online,
the following options are available for purchasing
tickets at a station:
• Ticket Vending Machines – these will accept
cash and most major credit/debit cards
• At the station Ticket Office.
If neither of these options are available at the station
(this may be because it is not possible to purchase the
type of ticket you require i.e. a concession ticket from
a Ticket Vending Machine or because it is out of order
and the station Ticket Office is closed) and you do
not have a pre-booked ticket, you should approach a
member of on board staff to purchase a ticket as soon
as possible.
7.3 An authorised collector must not charge a penalty fare under
rule 6.2 if any of the following circumstances applied at the
station where the person joined the relevant train.
a There were no facilities available to issue the appropriate
ticket or other authority for the journey which that person
wanted to make.
7.4 An authorised collector must not charge a penalty fare under
rule 6.5 if, when the person entered the compulsory ticket
area:
a there were no facilities available for selling the appropriate
ticket or other authority for the journey the person wanted
to make or for entering the compulsory ticket area;
Does that mean that if you want a ticket from a station other than the one you're boarding the train at, you can board the train ticket-less? (I realise the the advice to see the guard as a first priority is brilliant in all such circumstances, and it's a shame there's not a little notice at every such station mentioning this.)
If the ticket you require is from a different station, surely you already have a ticket to get you from where you are to the other station, so I don't think that would be a problem at all. You wouldn't be ticketless, after all.
What if the train is DOO?
See the ticket examiner?
