Mileages from closed stations.
matchmaker
8 Mar 2009
Central Scotland
I took a drive to Oban yesterday - just for a day out. The road runs close to the railway in several places and I noticed several mileposts which looked as if they'd had a recent coat of paint. I couldn't figure out where the mileages were worked out from until I got home and had a look at the John Thomas book "The Callander and Oban Railway". 54 years after the line was closed between Dunblane and Crianlarich the mileages are still worked out from Callander, which closed when the line closed in 1965.
Any other examples of this?
adrock1976
10 Dec 2013
Still in Scotland, the milepost at Gretna Junction just before the ex Glasgow & South Western Railway converges/after it diverges from the ex Caledonian Railway main line is measured from either Glasgow Bridge Street or St Enoch (both closed). Furthermore, the distance was measured via Paisley Gilmour Street and Dalry between Glasgow and Kilmarnock, with the track between Dalry and Kilmarnock having been lifted.
pdeaves
14 Sep 2014
Gateway to the South West
Loads. The northern bits of the former Midland Railway are measured via a closed route. Cornwall is measured via Plymouth terminus. Some of the Valley lines are measured from Bute East Dock (not to be confused with Bute Road passenger station). Severn Beach to Avonmouth is measured via Pilning.
The whole London Underground network is measured from a point that’s “off their map”, namely Ongar.
Rob F
17 Dec 2015
Notts
Milepost on Nottingham station is measured via the closed Melton route.
CyrusWuff
20 May 2013
Marylebone to Harrow South Junction (or thereabouts) and Mantles Wood (or thereabouts) to Claydon are measured from Mancheater via Woodhead.
Hence why Marylebone is located at 205 miles 77 chains.
Llama
29 Apr 2014
Rochdale Turnback siding mileage at Rochdale East Jn still shows as 14m 27ch, as it was when the turnback siding existed as the Up & Down Branch to Shaw & Oldham.
DelW
15 Jan 2015
The Aberystwyth and Pwllheli lines - other than the first 16 miles from Shrewsbury, they are measured from Whitchurch via Oswestry.
Fishguard, measured via Rosebush.
30907
Bearing in mind the thread is about distances measured from closed stations:
would Zero for the lines through Elephant & C be Holborn? And for the North London Line, Broad Street? Away ATM so can't check a Quail map, sorry.
Similarly, what about routes from Glasgow St Enoch/Buchanan St and Edinburgh Princes St?
Quail Vol 5 confirms your Holborn Viaduct zero point. There’s a change of mileage for the lines from Farringdon at the south portal of the extended Snow Hill tunnel.
