tbtc
At the moment there are a few "microfleets" (a token number of units that doesn't seem to have economies of scale), generally seen as A Bad Thing.
We quite often see arguments against certain schemes since they'd end up with a microfleet (which is seen as inefficient - more spares needed, harder to keep staff trained on such a small number of trains, less flexibility etc).
For example, Northern could run EMUs from Newcastle to Morpeth/ Chathill if they no longer ran through to the Metro Centre, but this would mean just one or two local EMUs at Heaton which would be more hassle than it's worth...
...the Bidston - Wrexham line may sit better with Merseyrail than ATW, but it wouldn't be worth the all-electric franchise taking on a couple of 150/153s to provide this service...
...SWT could have a 456 at Lymington but it'd be too much hassle to keep one such unit so far from their London inner-suburban home (not worth training staff/ too expensive to maintain one non-standard EMU, too far to run light each day to London) - a sledgehammer to crack a nut. PLEASE LET'S NOT HAVE THE LYMINGTON ARGUMENT AGAIN - I'm only using it as an example of where the hassle of a microfleet outweighs benefits.
Some of the microfleets are because there are only a handful of such units in the UK (LM 139s, ATW/Chiltern 121s).
Some of the microfleets are the result of fudge (like TPE getting nine young 170s rather than additional new 185s).
We seem to be moving away from these small fleets (even within TOCs - e.g. Northern putting their 155/158s in "Yorkshire" and their 156s in "Lancashire"/ "North East") - I suspect that some of the franchise boundaries in 2007 (when Central Trains were split up) were arranged along the lines of who operated what type of stock (158s to EMT and ATW, 170s to LM and XC)...
...however, electrification over CP5 will shake the map up a bit, which got me thinking - what microfleets could we see in 2019?
For example, electrification to Corby should see the MML operator running a small number of 100/110mph 387s (or equivalent) - rather than the same 125mph stock that they'll run on London - East Midlands/ Yorkshire services.
...plus a couple of "local" EMUs for the Leicester - Nottingham stopper (which presumably wouldn't be the same 387s?).
If the Wales & Borders franchise sees most of its 75mph DMUs (142/143/150/153) replaced by EMUs in the Cardiff/ Swansea area then it's going to be left with a small and geographically disparate number of "local" DMUs to run Blaenau Ffestiniog/ Bidston/ Crewe/ Heart of Wales/ Cheltenham/ West Wales services (would it be easier for the slow services in north Wales/ Cheshire area being moved to "Northern" for operational reasons, rather than running 150s all the way from Swansea when something goes wrong?).
If new 390s are built for London - Blackpool/ Bolton and London/Birmingham - Glasgow/Edinburgh then does that mean the WCML franchise will only have a token number of Voyagers (enough to run services to Chester/ Holyhead)?
With electrification of the Thames Valley branches, the GWML and the line to Basingstoke, will this leave a microfleet of DMUs at Reading to run the former Thames Trains routes to Gatwick and Bedwyn?
Allerton TMD may have only a tiny number of DMUs when lines from Liverpool to Manchester/ Wigan/ Blackpool are electrified (leaving only one unelectrified route out of Liverpool).
London Midland's DMU requirements are going to get low when Marston Vale, Nuneaton, Chase etc lines are electrified (leaving only Hereford and Shrewsbury on top of the Snow Hill 172s).
Any other (potential) microfleets I'm forgetting? (based on known electrification commitments)
(for the sake of argument, let's call a microfleet something in single figures)
