(micro)Hyperloop in Bavaria
Adlington
3 Oct 2016
Technische Universität München reports:
The first passenger trips are starting on the Technical University of Munich's (TUM) Hyperloop test track. The 24-meter-long experimental tube at the TUM Ottobrunn/Taufkirchen campus near Munich is Europe's first full-scale Hyperloop test segment; after a construction period of less than one year it was officially opened by Bavarian Minister-President Dr. Markus Söder and Bavarian Minister of Science and the Arts Markus Blume. The Hyperloop pod has been completely certified for passenger operations. Now the research group will focus its attention primarily on the drive system, levitation technology and vacuum behavior.
There is more information (including a predictable surfeit of hype), including photos and videos, on the project's website https://tumhyperloop.com .
I appreciate it is up to the academia to investigate speculative designs or solutions, and provide proofs of concept, if possible. Somehow, IMveryHO, hyperloop is a technical curiosity, not a practical solution.
The Ham
6 Jul 2012
Hyperloops (as the currently are) are primarily test tracks at present.
Whilst they could be useful in theory, there's a number of factors which need to be sorted. For example can you have more than one passenger pod in a section at a time?
If you can only have one pod, then you'll not really want overly long sections, otherwise capacity reduced. However make each section too short and you'll not see significant journey time savings.
Likewise, how are you keeping the air out of the tubes as you put the pods in? Make it so you don't let much air in and it's likely to take time to do, whilst make it quick and you'll have to pump more air back out again to minimise drag.
Of course the big issue is the cost of the stations, as if they're at surface level that's going to be costly (unless they're build on the outskirts of urban areas), whilst if they are underground (as the engineers linked with Crossrail or other tunneling projects will tell you) the cost of the station boxes are the significant costs rather than the tunnels.
