ValleyLines142
How long would it take to cover the entire Metrolink network? I fancy doing it one day!
I've come up with the following plan in order to do the challenge:
From Piccadilly, take the 216 bus to Droylsden (20 minutes)
Droylsden to Bury (44 minutes)
Bury to Altrincham (48 minutes)
Altrincham to Eccles changing at Cornbrook (44 minutes)
Eccles to East Didsbury changing at Cornbrook (49 minutes)
East Didsbury to Rochdale (60 minutes)
I'm hoping that either the Altrincham to Eccles or Eccles to East Didsbury (both with a change at Cornbrook on the way) does go via MediaCity.
So, by adding that up, it comes to 4 hours and 25 minutes (265 minutes).
Does this look achievable? Or does my plan need improving. Please say if it does, any advice is much greatly welcomed. Thanks!
Remember that the section from Droylsden to Ashton opens on 9 October if you want to include the full East Manchester Line.
telstarbox said:You can get trains from Victoria to Rochdale, Victoria to Ashton, or Piccadilly to East Didsbury if you want to avoid doubling back.
You're not going to get a call at Woodlands Road and the direct Eccles - MCUK - Cornbrook in on that plan you've got - last tram at Woodlands is about 16:00, first tram Eccles - MCUK direct isn't until almost 20:00. I'd suggest, if you want speed rather than all the track, is running from Broadway to MCUK, then tram from there to Cornbrook.
Just make sure to add in loo stops to your itinerary, there aren't many around and after going all the way out to Rochdale and back, I was bursting!![]()
