Merseyrail legacy fleet updates (Class 507/508)
zain_031
16 Aug 2024
Merseyside
Correct me if im wrong, but it looks like 018s last diagram is 2C68, then 5R41 to Birkenhead Central, unless it is subbed for a 777 at some point.
MR-507508
17 Jan 2020
North West
Can anyone confirm which unit is stabled on platform 3 at Southport at the moment (could be a Class 777), it has come from Kirkdale depot and appears to be taking over from 507029 on 2G61.
MR-507508
17 Jan 2020
North West
Unit required to replace a 777 from the West Kirby line. Replacement unit appears to be coming from Kirkdale depot as 5T84. Could well be 507029 which has moved ECS from Southport to Kirkdale depot this morning.
Whatever unit replaced the 777 on the West Kirby line has been swapped over with the initial 777 which had an issue earlier this morning.
kylestoast
4 Jan 2024
Lancashire
The 11:40 to West Kirby at LVC is showing as 3 car on the boards, will have a look what it is when it turns up
It's 777038 on 2W19, not a 507
25 Feb 2024
018 still out and going strong, now running the ex 18:12 off Chester, brilliant sound and acceleration
WirralLine
4 Jun 2024
Wirral
Managed to catch it over to Liverpool earlier and then caught it back later on, sounds brilliant and couldn't fault it.
Overheard some old ladies near me talking about how nice it was to have one again as the new ones are "so unreliable" - made me chuckle!
simonmpoulton
25 Jun 2011
507018 might carry on doing the Chester's tomorrow but we'll have to wait and see. There appears to be a lot of 777's parked up around the place with faults - two at Hooton and one at Rock Ferry come to mind and have been there for days.
WirralLine
4 Jun 2024
Wirral
Major shortage of 777s due to some major faults with the TCUs across a large proportion of the fleet, they've been dropping like flies and not a quick/cheap part to replace. Expect 507s to be filling in for a while.
Barnsley
20 Feb 2010
Barnsley
507018 is allocated the following for today:
0540 Hooton - Chester via Liverpool
Then Chester departures at 0712, 0857, 1042, 1227, 1412. 1557, 1742, 1927, 2100 and 2231
zain_031
16 Aug 2024
Merseyside
Currently onboard 507018 on 2C12, sounding amazing as always. Have not been on a Chester 507 scince I believe January.
TheSel
10 Oct 2017
Southport, Merseyside
I've just got to James St. Seems nothing is running? Rumours of someone hit by a train.
Hope that's not true, but if it is, then hope everyone involved will be OK.
D6700
13 Mar 2010
At Lime Street, there are 3 fire engines, 3 ambulance incident units, a first responder ambulance, an actual ambulance and a Network Rail MOM van.
tnxrail
8 May 2011
Is there an off chance one could run same day as tour if needed or will all trained drivers be working the tour.
zain_031
16 Aug 2024
Merseyside
Still onboard 018, waited at Rock Ferry for a while then reversed at Birkenhead Cetral, now on its way back to Chester on 2C19
D6700
13 Mar 2010
Thank you for the confirmation. Further updates will be appreciated - I'm currently heading to Chester on the 11:47 TfW from Liverpool, so expect to miss the return working at Chester, but will try to pick it up at some point.
