Merseyrail Daysaver vs Saveaway (+ early morning validity)
jednick
1 Apr 2013
Worcester
I'm in Merseyside for two days. I can't decide whether to get a Saveaway or a Daysaver ticket.
Are the main differences betwwen the two the fact that the Saveaway can be used additionaly on the ferry, buses and the railway line to St Helens (and also is slightly more expensive)?
Also, both tickets can be used before 6.30am on weekdays. What happens if I get on a train, for instance, at Southport just after 6am and arrive at Liverpool just before 7am. Are both these tickets valid as I boarded my first train before 6.30 but I am still on the same train for some time beyond 6.30?
Djgr
30 Jul 2018
Not just St Helens but also Lime Street to Hough Green, Lime Street to Newton le Willows, Lime Street to Garswood, Headbolt Lane to Rainford, Southport to Meols Cop and Bidston to Heswall (any TOC)
Polarbear
24 May 2008
Birkenhead
Daysave only allows travel on Merseyrail services, whereas (as outlined by @Djgr) a Saveaway is valid on almost all public transport within Merseyside. For the very small price difference, I would always recommend getting a Saveaway for added flexibility.
Regarding journeys starting early morning, as long as your journey starts before 06:30, the journey can be completed after 06:30.
nwales58
15 Mar 2022
notsure
Does the starting before 6:30 a.m. allow for a change of train?
See their web sites:
Merseyrail Day Saver (https://www.merseyrail.org/tickets-passes/daily-travel/day-saver/)
If you are using a Day Saver ticket and need to change trains to complete your journey during the morning peak (06:31 – 09:29) a Day Saver ticket will not be valid.
Merseytravel Saveaway (https://www.merseytravel.gov.uk/tickets-and-pricing/ticket-types/saveaway-ticket/)
Each time you board and alight a bus, or pass through a rail or ferry terminal, barriered or not, it counts as a separate journey. If you are making consecutive journeys, both journeys MUST start during off-peak time for this ticket to be valid. If you commence any journey during peak time, you must buy a separate ticket
1D54
1 Jun 2019
Doesn't look to be railcard reduced tickets available.
JBuchananGB
30 Jan 2017
Southport
Railcard discounts are not available with Daysaver or Saveaway, but are available with Anytime tickets, and with OffPeak tickets to stations off the Merseyrail network. This can result in fares below the Daysaver/Saveaway fare.
Djgr
30 Jul 2018
But the all zone Saveaway for Young Persons is half price (£3.40 instead of £6.80) and young person means 18 and under.
1D54
1 Jun 2019
Ah yes, remember i now purchased a day return from Liverpool Central to Sandhills from a non Merseyrail ticket office and Senior Railcard discount was applied.
lyndhurst25
26 Nov 2010
Section 5.1 of the Saveaway T&Cs seems to have changed at some point.
It used to be "Each time you pass through a rail ticket barrier, it counts as a separate journey", etc. So you could start a rail journey before 6.30am and, for example, change between Northern and Wirral lines at Liverpool Central, catching the second train after 6.30am, as you would not have to pass through a ticket barrier.
Now it is saying "Each time you board and alight a bus, or pass through a rail or ferry terminal, barriered or not, it counts as a separate journey. If you are making consecutive journeys, both journeys MUST start during off-peak time for this ticket to be valid. If you commence any journey during peak time, you must buy a separate ticket". This is ambiguous - what is the definition of a "rail terminal"?
JBuchananGB
30 Jan 2017
Southport
For short journey like that a discounted Anytime Day return can be cheaper than the single zone Daysaver. MerseyRail ticket office should sell it to you if you ask.
Djgr
30 Jul 2018
There is nothing to suggest that the OP is planning such a short (essentially walkable) journey.
In summary:
If you are planning a short or peak time journey just buy a normal ticket.
If you are planning to explore the local railway network for the day but ONLY MERSEYRAIL then Daysaver.
If you are planning a more comprehensive day using multiple TOCs (Merseyrail, Northern, TPE, TfW, East Midlands, LNWR) and train types and/or including a trip on the unmissable Mersey ferry then Saveaway everytime.
Not that short if you have a Railcard. A discounted Anytime Day Return is cheaper than a Daysaver if doing a journey as long as Ormskirk to Liverpool.
As for the Saveaway vs Daysaver I would probably choose the former even if a little costlier as it provides the insurance of bus and ferry validity without having to wait for acceptance if there is disruption. Also out of principle as I consider that with the very low difference in price it is just a revenue grab a bit like Northern and TPE Only fares 10p apart and so should not be encouraged through sales.
Djgr
30 Jul 2018
Current LCR plan is to look to take Merseyrail concession in house and oust our Dutch friends. Can't see a cynical scammy product such as Daysaver surviving this!
Kite159
27 Jan 2014
West of Andover
It depends if the Daysaver is an idea from Transport UK/Serco or is an idea from someone within Merseytravel itself, in which case even if you remove the private operators the "Merseyrail Only" ticket will most likely remain.
For a fairly long time there has been a bus only "Solo" PTE ticket, currently 80p less than the all zone Saveaway (but 70p more expensive than the single area version, but valid all day) so who knows?
Djgr
30 Jul 2018
Pretty sure that these resulted from pressure from the private operators, who have yielded significant power in the privatisation era.
But if your vision is an integrated public transport network then you shouldn't base your approach to fares on whether the train is painted yellow or blue or whether the mode of transportation has tyres or not.
gray1404
3 Mar 2014
Merseyside
Merseyrail need to bring back the Off Peak Day Returns for post 9.30am travel. Most people are making a return journey to Liverpool Central and do not need a ticket allowing unlimited travel.
