Merseyrail Class 777 introduction updates
Northerngirl
16 Aug 2023
Wirral
You know what I find interesting and only just realised. The 777s don’t have the orange door indicator on the outside. Are there any other units without this operating ?
I noticed that the other day too, they do however have a lighbar above the door that seems to do a similar job
Liverpool 507
17 Jan 2018
Merseyside
That’s only on one side where the doors are released so is no good of you’re on the opposite side
Monday 22nd - Three failures this morning on the Southport line within an hour of each other (777009, 777034 and 777049). Two further failures this afternoon on the Southport and West Kirby lines - (777014 SOP/HNX & 777008 WKI).
Some of the above have been in service well over a year and should be well bedded in by now. Not good.
24 Oct 2015
And what were the failures? This could have happened to a train that could have been in service 5-10 years?
800001
24 Oct 2015
The point being that these trains are still plagued with technical issues.
I’ve spent many a day riding these, many a day spotting at stations they service, also using these for commute and social reasons , and yes there are delays, however other the last few months I’ve observed many hours where the trains run exactly to time, and the delays I did witness were due to external factors, ie trespass, track issues etc.
Plagued with problems may be slightly stretching reality.
prod_pep
8 Aug 2010
I really don't think so. There are still multiple failures of 777s on a daily basis due to faults. A cursory glance of Merseyrail's Twitter feed betrays this fact, and some early morning and late evening failures are not even shown on there. Things are a tad better but it's glacial progress in the main.
And no, the old 507s are not immune from failure, yet their reliability is vastly superior.
karlbbb
26 Jul 2009
Once deliveries and acceptance of all 777s is completed, are we expecting Merseyrail to "go back" to the same timetable as previously, with the same services doubled to 8 cars etc? Or will it be a new timetable?
Selfishly looking forward to the 1616 from Central to Ormskirk becoming an 8-car again (5G56 runs from Kirkdale to Ormskirk and joins a service already waiting in the station).
Skie
22 Dec 2008
New timetable. Back before covid they even had an indicative table that showed how many minutes would be saved per journey. Rotherham was even quoted as saying a train every 13 minutes which would be a bit odd.
Vinnym
26 Jun 2018
Election pending.
Peter Sarf
Croydon
A train every Thirteen minutes would surely be more likely to be every Twelve minutes as in exactly Five trains an hour ?.
Bikeman78
26 Apr 2018
How much time can be saved? Anecdotally, a 777 doesn't seem much better at keeping time than a 507. I suspect longer dwell times will largely cancel out any acceleration benefit.
prod_pep
8 Aug 2010
Nowhere near as many minutes will be saved as that table suggested. The 777s actually seem to struggle to keep to time with the current timetable in sections of closely-spaced stations, the loop tunnel being one example. They can clearly do longer gaps a little faster than 507s, however.
The expected saving on the Southport line was nine minutes each way I think, which is a gross exaggeration. Perhaps more like two or three is realistic with the current setup?
Bevan Price
22 Apr 2010
They need to find a way to reduce station dwell times.
paddyb6
21 May 2018
They do well Hooton to Chester, often arrived early at Bache.
Skie
22 Dec 2008
It may have been 12 mins! This was 4 years ago, memory for Politician bluster isn’t my strong point.
urbophile
26 Nov 2015
Is there a reason why there is often a long wait between the train stopping and the doors being released? I can see the need to check before departing, but why can't they be released immediately?
Grumpy Git
13 Oct 2019
I see you're not familiar with LNW on the Liverpool-Birmingham route then? ;)
Peter Sarf
Croydon
I have really noticed this pause while the guard decides if the driver has parked properly. That was on a train Euston to Wolverton and return. Never noticed it before. So are we all getting more cautious.....
8A Rail
6 Dec 2012
Mars
Early this morning, No 777029 and 037 were delivered to Kirkdale from Long Marston, which leaves three remaining at the latter location.
Kirkdale C.S. = 001 to 032 inclusive, 034, 036 to 039, 041 049, 051, 140, 142, 144, 146, 148, 150 and 152.
Long Marston = 043, 045 and 053.
Europe = 033, 035 and 047
karlbbb
26 Jul 2009
Anecdotally, it feels like the 777s have nose-dived in reliability over the past few days. It's been a little while since I've had this many alerts from the Merseyrail Twitter account about train faults.
DJH1971
10 Jun 2012
St Helens, Merseyside
When are the final 3 units set to arrive in the UK?
73001
2 Jun 2010
If you try to board the train from the wrong side you have more to worry about than whether there is an orange light or not.
The conversation was about rail staff crossing the tracks at places like Chester, not boarding the train. If the side lights are on they can cross knowing the train isn't going to move off. Can't tell with 777s.
1D54
1 Jun 2019
Simply from an enthusiasm side of things where is the best place to go and park oneself for an hour or two so as to see as many of this particular class as possible?
8A Rail
6 Dec 2012
Mars
Not that easy as they work on two separate circuits, i.e. Wirral and Northern lines. Ignoring the Underground Stations, in order to keep away from any possible hassle, certainly for the 'Northern' lines, suggest Sandhills Station as all Northern lines converge in that area. On the Wirral lines, for Chester / Ellesmere Port either Birkenhead Central or Rock Ferry, for West Kirby / New Brighton, would suggest Birkenhead North Station. Given you propose time span, I suggest go to Sandhills Station, other members may suggest something different?
Liverpool 507
17 Jan 2018
Merseyside
The current unit diagrams (including the remaining six 507 diagrams) have been written in to the June - December 24 timetable. The proposed diagrams from June have been removed. Will be interesting to find out when the remaining nine units do leave the network.
