Merseyrail Class 777 introduction updates
1 Dec 2022
Lancashire
777008 and 010 also gone again today. Mix of CCTV fault, PIS fault, "web socket" fault. Believe one had a step board fault too. As always not sure which had what fault and when/where.
777013 was the one with the step board fault at Sandhills. Apparently it wouldn't retract.
I would have a look at any of the threads on here about any new trains since forever. This level of faults is entirely typical, for all sorts of reasons. It would be more surprising if this didn't happen
Not all new units are coming in with this many faults though. Certain TfW units for example have to do a significantly higher amount of fault free milage before they are accepted, and as such they are experiencing fewer faults. If Merseyrail had done more testing rather than rushing them into service and making a big song and dance about their shiny new trains, these faults wouldn't be as common (they would still occur, I agree, but it's likely they wouldn't be to this extent). Reliability has been shot to pieces on the Kirkby and Ormskirk lines and the network cannot be trusted to get you from A to B without cancellations currently.
Bikeman78
26 Apr 2018
Has any other train fleet introduction been quite THIS bad? I'm not sure i can recall anything where every day would see multiple failures of an already very small fleet, and for months on end. I find this level of failures frankly shocking?!
The Networkers were dire 30 years ago. The Met Camms and the BREL units caused all sorts of problems when they coupled up. The 357s were grounded after a number of failures and the three car 310s brought in from Birmingham to cover for a year. The 323s weren't great either. They shut down in frosty weather.
L401CJF
16 Oct 2019
Wirral
Is the PIS system related to a more important /critical system on these units?
A lot of the units taken out of service are due to "PIS stuck on not in service" (or just stuck) according to internal emails I've been shown. Anywhere else in the country manual announcements would be made by crew and the show would go on. Half the TFW journeys don't have a valid input code for the PIS so they trundle along with TFW showing on the displays.
Even a few of the legacy 50X units have dodgy PIS these days (124 being one which has been broken for months) which get stuck yet they continue in service.
prod_pep
8 Aug 2010
777 failures have still occurred virtually daily over the last few weeks, so they have been only marginally better at best. Certainly, this week has been particularly terrible.
Some seem especially prone to faults, 777001 (another with reported problems yesterday) and 777018 in particular, whilst 777049 seems to be fairly dependable as these units go.
Bikeman78
26 Apr 2018
You pretty much can make a train run forever, just like you can a car (there are Ford Model Ts out there, and enough preserved railway kit). It just comes down to when it ceases to be economic to do so. Trains are more like houses than cars in that sense which is why 40-50 years is a typical lifespan. Parts can always be fabricated and electronic equipment replaced with more modern kit.
Note, I don't think they should be keeping 50x running indefinitely (just replace the awful seats on the 777s :) ), but if they did want to it's possible.
There are PCC trams from 1966 still running in Antwerp. As far as I can tell, they are no less reliable now than they were 50 years ago. The Belgian AM75 pig nose trains have just been extensively refurbished and will be fitted with ETCS. They will quite likely see 60 years service. As you say, EMUs will basically carry on forever if properly maintained and overhauled.
As you say, taking a train out because the PIS is broken is absurd. I don't believe that any passenger would rather have no train at all rather than one without automatic announcements.
jamesst
4 May 2011
Merseyside
The pis is linked into other systems on the 777s rather than a standalone item on the 507/8s.
childwallblues
3 Jul 2014
Liverpool, UK
I was on 777049 on Tuesday. The unit arrived at Sandhills showing OUT OF SERVICE as its destination but still carried on to Kirkby. I travelled back on it to Liverpool Central and on arrival carried on in service back to Kirkby.
43066
24 Nov 2019
There were big problems with 700s at first, the 710s had problems and the 701s are now. People have short memories!
These days it can go beyond just having no announcements; the PIS is integral to modern trains’ workings, and potentially won’t allow doors to be opened etc. if it throws a wobbly. This was part of the problem with the 700s initially.
Lewisham2221
23 Jun 2005
Staffordshire
I was waiting for someone to say this. With reference to both the 777s and TfW 230s, could it just be that the niche nature of the units means that failures stand out more/have more impact? Didn't Virgin have to keep a couple of loco hauled sets on standby when the 390s were first introduced?
Sam 76
10 Nov 2021
Southport.
I think that will certainly be part of it. Part of the problem on Merseyrail is when one breaks down there is nowhere to go a lot of the time so it causes significant disruption.
They will bed down eventually. Does anyone in the know have the miles per fault numbers between now and when they first started ?
childwallblues
3 Jul 2014
Liverpool, UK
See my post 4868
1 Dec 2022
Lancashire
Are you able to elaborate? Seems that modern trains are over complicated.
The PIS is now linked to a whole host of things, including the CCTV, the 'panel' that guards tap back on and weirdly part of the fire system (the logic was if smoke was detected the announcements would automatically be linked so they can tell passengers to move out of the affected area).
So I'm guessing some of the PIS faults are affecting the guards ability to tap back on the train (therefore can't dispatch) and the fire system (therefore probably not safe to run if the alarms won't work) so the trains have to be pulled out of service until the faults are rectified.
Bikeman78
26 Apr 2018
Thanks for the info. I do think the passengers would probably move without being told though! I certainly would. With such complicated systems, will these trains ever be reliable?
ExRes
16 Dec 2012
Back in Sussex
Short memories indeed, I don't have any problems recalling the amount of time I spent at Farringdon when the 377s were introduced on Thameslink, units shutting down on the AC/DC changeover, doors not working, no PIS, units being taken out of service and, of course, delays to service after service, they settled down like the 777s will
1 Dec 2022
Lancashire
You would like to think people would move out of the affected area.. but have you met the general British public?
Hopefully they start finding solutions to these faults (or what's causing all the faults) soon so they can improve the reliability, preferably before they start pushing them out to more lines, or making Ormskirk 777 operation only.
Peter Sarf
Croydon
Gosh how complex trains have become. That is always going to make the risks mount up.
Indeed. We quickly forget the worst.
Pacef8
21 Mar 2020
Wirral
Saturday 13th May
Ormskirk:
  • 0650 Ormskirk - Moorfields is cancelled
  • 0735 Moorfields - Ormskirk is cancelled
  • 0810 Ormskirk - Moorfields is cancelled
  • 0855 Moorfields - Ormskirk is cancelled
Kirkby line:
Some services will be diverted to Aintree.
Rail replacement buses have been requested to run between Aintree & Kirkby.
  • 0713 Kirkby - Moorfields is cancelled
  • 0745 Moorfields - Kirkby is cancelled
  • 0813 Kirkby - Moorfields is cancelled
1 Dec 2022
Lancashire
Saturday 13th May
Ormskirk:
Kirkby line:
Ormskirk was due to a train fault, but the cancellations at Kirkby are apparently due to a track fault at Kirkby. For once I don't think the 777s can be blamed for that one (unless they've somehow managed to break the track).
(Edit: removed link to service alteration details from the Network Rail Website)
Bikeman78
26 Apr 2018
Well they got off that 466 near Maidstone pretty quickly! I'm going to hazard a guess that they didn't need to be told.
Babybirdrobin
3 Mar 2022
The Crouch Valley
That’s quite alright. It wasn’t intended as a personal criticism, I just wanted to clear up any possible confusion. There may be younger contributors who may be misled into believing that there were ever more than 3 PEP units.
To be fair I didn’t realise that and have always thought the were PEPs.
The_Train
2 Jun 2018
Not what Merseyrail twitter are reporting
1 Dec 2022
Lancashire
Friend with access to the system has finally woken up.
777049 failed at Kirkby because it couldn't get any power from the 3rd rail. Delay report wasn't clear if it was a fault with the unit itself being unable to collect power or a fault with the tracks being unable to provide the power.
777049 has also has a PIS already today apparently so it's not doing particularly well..
Either way, it's fixed now and services are resuming.
Sam 76
10 Nov 2021
Southport.
Has there been a recent software update to these? It’s like at the start again. 2 have gone pop already this morning :(
Vespa
20 Dec 2019
Merseyside
I'm about to go to Central station, doesn't sound promising.:|
On the 9.31 to Ormskirk 777 Eurovision unit, noticed 9.35 to Kirkby is cancelled a 4 car train so it can only be a 777.
karlbbb
26 Jul 2009
The 777 on the Kirkby run that went through Kirkdale at 0730 had "NOT IN SERVICE" on the external destination boards, although the internal displays all looked to be working (I was on a train into Central going the opposite way).
danbarnstall
1 Apr 2014
Yes there has and I’m led to believe we may see a few short term changes to 777 running over the coming days to fix these software issues.
