Merseyrail "Badger Line" and "Tech system" do they still use use them?
thenorthern
27 May 2013
While on Youtube a video on Merseyrail fire safety video from 2004 popped up and I don't know why but I watched it. Two things caught my eye which are the "Badger Line" and the "Tech System". I was wondering if they still use them. Both are used in tunnels where radio signals don't work very well.
The Badger Line is a telephone line which the emergency services would plug their own self-powered phones in to communicate with emergency services workers at each level of the underground station. There is a link to show it in the video below.
The Tech system is for train drivers in the tunnel and involves attaching two clips to copper wires at the side of the tunnel to allow communication between the cab and the signal box. I assume if there is an emergency in the tunnel or if the train is waiting at a red signal where rule 55 would apply. Again here is a link to show it in the video below.
Obviously by modern standards both these are old bits of kit but I was wondering if either are still used?
Wapping Dock
29 Nov 2010
Yes, the TEC system is still in use. You can see the TEC boards at the ends of the underground platforms on the Loop.
Dr Hoo
10 Nov 2015
Hope Valley
TEC is Tunnel Emergency Communication system, I believe. Rather ‘basic’ and not very ‘tech’!
jamesst
4 May 2011
Merseyside
Both of them still there, whether you find a member of staff thats actually used them in the past 20yrs is a different matter!!
Dr Hoo
10 Nov 2015
Hope Valley
Is it similar to or the same as the London Undergrounds tunnel telephones system?
From my time on Merseyside (45 years ago now) I was told that it was essentially identical. Tripcocks too. Applying the insulated TET (Tunnel Emergency Tool) turned off the detection current in the wires, put on the tunnel lights and allowed you to clip on the TEC phone. I don’t recall it ever being used in ‘anger’ rather than training. Still got the book somewhere.
Ianigsy
12 May 2015
The TEC Failure boards are certainly seen on a fairly regular basis!
cool110
12 Dec 2014
Preston
Interesting point in that is that the 777s don't have the TEC phones, only the emergency switch off tools.
thenorthern
27 May 2013
I read somewhere that they were installing Leaky Feeder into the Merseyrail tunnels which might be what is replacing the T.E.C system.
cool110
12 Dec 2014
Preston
It does also say that the T.E.C. phones in the 507/508s can be used as an alternative when GSM-R fails, so that must have been done at some point before the 2019 amendments. Presumably once the last of those go the phone parts will be decommissioned leaving it just as an isolation method.
