Mechanical/engineering background?
Romneym335
7 Dec 2015
I am looking at a career change to trainee driver however I have no mechanical/engineering background or qualification.
Obviously this sort of background or qualification would be advantageous to any future application form. I am therefore looking at possible college courses which I can complete part time to cover evidence this area.
Does anyone have any recommendations on any courses to do?
greatkingrat
20 Jan 2011
The vast majority of trainee drivers have no engineering background or qualifications. I would not recommend doing a course solely for that reason unless you would be interested in working in engineering roles.
Romneym335
7 Dec 2015
Ok that's interesting. Someone told me that LM recently stated that a qualification in this area would be advantageous for the role of trainee driver.
harrier76
26 Sep 2013
Notts
I passed train driving assessments a couple of years ago. I have an ONC in mechanical engineering so i thought id breeze the mechanical comprehension test but to be fair, it was no advantage being an engineer. The test was made up of picture questions that weren't as clear or in the same standard as real engineering diagrams so if anything it made it more tricky.
I think if you're not from an engineering background youd be just as well prepared if you googled some of the test pictures and taught yourself to pass the test rather than a crash course in engineering etc.
Bromley boy
18 Jun 2015
Definitely not worth it in my view. I had no engineering or technical background at all when I succesfully applied for a trainee driver position. The main requirement is of course to pass the assessments and DM interview, irrespective of other qualifications you hold.
A technical background may mean you pick up concepts on the traction course more quickly, but even this is of no real benefit as the course is designed for people with no mechanical experience.
Romneym335
7 Dec 2015
Thanks all, I really appreciate all your views. I'm just determined to give myself the best chance possible, but if it's not worth doing then I won't.
G136GREYHOUND
29 Mar 2014
Don't sweat it, it makes no odds, it's been years since I did the Psycho tests to get in, more years than I want to acknowledge, but I had no electrical or mechanical background.
A history degree and being a Scaley was all I had experience in and I managed to scrape through, so just go for it and relax
Bromley boy
18 Jun 2015
I reckon the best thing you can do is ensure you thoroughly research the process itself. Plenty of information out there, but sorting through it can be time consuming. As you probably know you only get two attempts at the process so it pays to research it well.
You can't prepare for the assessments, as such (with the exception of group bourdon), but make sure you research the questions asked in the multi modal interview and think about examples to use in advance.
Best of luck with it.
TDK
19 Apr 2008
Crewe
The best attribute with the tests and application is logic and an understanding on what is required for the role. To be a train driver it is advantageous to have some engineering background but it doesn't mean you have to have it.
kelv
20 Feb 2015
cheshire
Likewise with the ONC and did a 4 year apprenticeship as a fitter/turner. Did a lot of CNC programming & setting after that. Any engineering course that is less than a full apprenticeship is in my opinion missing stuff out, a bit like doing a quick course to be a driver and not covering everything that would need to be learned which 1 day has the potential to leave you completely stumped.
The only thing that I see as any kind of relevance from engineering really is that depending on what you was manufacturing in some jobs a high level of concentration, accuracy & attentiveness is required. Also it can be a dangerous environment so safety has to be adhered to although in a different context to on the railways, more a case of personal safety really and in many instances something that you have to take on yourself as the industry is rife with factories that view you as completely expendable and have little to no regard for your safety or welfare.
when I've looked at railo engineering jobs I've looked at wheel lathe jobs but outside of that I've not really seen anything else that relevant to my previous skills. Maybe someone on here can point out jobs that would utilise those kind of skills ?
I believe some of the track maintenance vehicles have machining capablities?
so my impression is that those fellas will be machinists that have then become drivers ? or am i barking up the wrong tree there with that assumption ?
