May 2013 timetable changes?
MidnightFlyer
16 May 2010
Does anyone know of any changes to train times / services this coming May? Having a quick glance through NRE doesn't seem to highlight any changes and I've not read in any magazines of anything planned. Of course generally speaking the summer timetable tends to only feature minor alterations and extra seasonal services, but does anyone know if anything of actual note is changing?
Cheers
Some minor changes for Southern at London Bridge in connection with the permanent reduction from 9 to 6 platforms. Most significant is that one up morning peak train has to go to VIC instead.
SprinterMan
20 Sep 2010
Hertford
Greater Anglia's summer Saturday LHCS serives to Great Yarmouth are starting up again:
1V18 1000 London Liverpool Street to Great Yarmouth
1V33 1040 Great Yarmouth to London Liverpool Street
1V28 1230 London Liverpool Street to Great Yarmouth
1V43 1310 Great Yarmouth to London Liverpool Street
The North Wales coast line is seeing more Holyhead to Manchester trains on a Saturday & Sunday:
Sat
1H80 0425 Holyhead to Manchester Piccadilly
Sun
1H80 0750 Holyhead to Manchester Piccadilly
1H87 1430 Holyhead to Manchester Piccadilly
1H88 1540 Holyhead to Manchester Piccadilly
(Of these, only 1H87 is running currently)
The Halton curve parliamentry train will be running again:
2F80 0753 Chester to Runcorn
Adam :D
northwichcat
23 Jan 2009
Northwich
Some Northern services are to get longer dwell times at some stations from the May timetable change to allow for higher loadings. Replacing Pacers with trains with 4 sets of double doors for every 2 carriages would probably have the same effect.
heart-of-wessex
11 Jun 2005
Trowbridge
I've heard 2O67 Bristol - Weymouth will be a Class 67 again, according to someone I know at Transport2000, don't believe it until I see it though
Chester025
29 Jun 2008
That would be great, but as is so often the case the gen has probably come from a platform end...
ffm
20 May 2012
Actually you could have saved some words there. My version would be 'Replacing Pacers with trains would help' :D
anthony263
19 Aug 2008
South Wales
Considering FGW will need something to cover for the class 165/166's going away for refurbishment the idea that FGW could go back to loco hauled trains for a short period might not be so unbeliveable.
After all 150's 150921 & 150927 both being 3 carriage units could go to reading to work alongside 150001 & 150002 to work on the Reading - Bassingstoke and thames valley branchlines. The loco hauled trains could then work certain busy services around Bristol like they did a few years ago.
Unlikely to be 67's though now.
PHILIPE
14 Nov 2011
Caerphilly
Hardly think so as there are rumours about pulling the 150s away from Reading anyway and transferring to PM'. The Saturday Weymouth was DMU worked last Summer so it is hardly likely to revert back to loco hauled again.
heart-of-wessex
11 Jun 2005
Trowbridge
I kept hearing it was supposed to carry on each year with HST's. Obviously didn't happen but of course it technically did but for Olympic relief (only ran a couple of times in service IIRC?)
The HST stop boards are still there just in case, depends if they are ever needed again!
Manchester77
4 Jun 2012
Manchester
London Underground will have a May timetable change on the Sub Surface lines to coincide with the S7 stock trains entering service on the Circle Line
barrykas
19 Sep 2006
Chiltern are proposing to extend the Sunday Aylesbury - Amersham shuttles through to Marylebone, providing a half hourly service in the afternoon, switching two pairs of Marylebone - Aylesbury via High Wycombe (and return) trains back to separate Marylebone - Princes Risborough and Princes Risborough - Aylesbury services to allow extra freight paths along the branch, adding three extra Marylebone - High Wycombe services on Sundays, and adding contingent rights to call at Stratford-upon-Avon Parkway when it opens.
Johnny Lewis
9 Jan 2011
York
According to TRUST, Grand Central will achieve the extension of their fifth train which currently runs as 12.53 Kings Cross to Hartlepool and 14.47 Hartlepool to Kings Cross to run to and from Sunderland. The southbound train will depart from Sunderland at 14.06 and have a 17 minute dwell at Hartlepool to pick up it's current path. It still won't call at Thirsk.
craigwilson
3 Jan 2010
Buxton, Derbyshire
Looks to be some minor changes to the Ramsgate -London services along the Chatham Main Line, with a couple of morning peak services retimed by 1-2 minutes to allow a call at Newington:
0609 Ramsgate - Victoria will depart at 0608 from May
0659 Ramsgate - Cannon Street will depart at 0657 from May
Also, the 0700 Broadstairs - St Pancras will now depart 2 minutes earlier, seemingly for no other reason than introducing some slack - it's timetabled to arrive at STP at the same time as now.
mister-sparky
28 Jan 2007
Kent
...Also, the 0700 Broadstairs - St Pancras will now depart 2 minutes earlier, seemingly for no other reason than introducing some slack - it's timetabled to arrive at STP at the same time as now.
Means that it must've been running late alot lately, their way of getting out of delay refunds. southeastern has so much slack in their timetables it's ridiculous sometimes.
306024
23 Jan 2013
East Anglia
Southeastern has to be one of the most complicated networks to timetable, with numerous flat junctions and many different services. Try timetabling all that lot without pathing time :)
Most minor odd minute retimings are as a result of analysis of performance data. With more people using the railway station dwell times have to be adjusted to reflect this.
Batman
27 Jun 2011
North Birmingham
London Midland 08:05 Rugeley Trent Valley to Birmingham New Street is timed to depart Rugeley at 08:02 and will make extra stops at Landywood, Bloxwich North and Bloxwich. These are stops that were withdrawn last year.
However, the 07:07 Birmingham-Rugeley service will now run fast from Walsall to Cannock.
Stats
27 Sep 2009
The Newington stops replace the 0545 Dover to Cannon St and 0705 Ramsgate to Victoria both of which will cease to call at Newington.
London Midland are proposing to provide an enhanced service from Birmingham to Stratford-upon-Avon by extending a number of services from Whitlocks End: http://www.networkrail.co.uk/browse... 10 april 2013/lm 42 sa - form p draft v2.pdf
They are also proposing to extend the SX 0614, 0714, 0814 and SO 22:14 Birmingham to Coventry services to Northampton.
Southern are proposing to bring 12 ECS moves between Brighton and Hove into passenger service on Sundays.
craigwilson
3 Jan 2010
Buxton, Derbyshire
Ah, I missed that.
It would also seem that from the May timetable, the 0705 Ramsgate - Victoria attaches at Faversham to a Dover portion, so will this be a 12-car (8-car - as now - from Ramsgate, attaching to a further 4 coaches at Faversham) or an 8-car (two 4-car portions)?
Class377/5
19 Jun 2010
No news on changes to Southern at London Bridge with platforms taken out of use at rebuild properly starts?
High Dyke
1 Jan 2013
Yellabelly Country
Not looked yet, but Sunday services in Yellerbelly Country will be restored on the Lincoln - Mkt Rasen - Grimsby route and Skegvegas services will commence earlier for the summer than they are in winter as per usual.
87015
3 Mar 2006
GEML/WCML/SR
Shouldn't need much, platform occupany isn't that tight even in the peaks and outside of that you are laughing anyway. All the Peckham Rye stuff (which remains 6tph in the peak so includes the Dec extras which replaced the SLL) moves into Plat 13, everything from 13 is shuffled into the currently unused P10 and in the peak 8-12 are presumably tightened up a bit more for the mainliners - can't see any less trains in a quick glance at the PM peak.
If they can work reliabily what is in on paper then everyone is a winner as no trek to 14-16 is required from May onwards.
Birdbrain
16 Jun 2007
Is there any way to get hold of the full timetable for say FGW or are they just in the journey planner as yet?
Stats
27 Sep 2009
The only change Southern have applied for is the 0725 ex Tonbridge to be diverted to Victoria.
I see SWT are making the usual extremely minor changes to their overall timetable, one of only two changes is that on weekdays the 1915 Waterloo to Havant is being extended through to Southampton Central by bringing the current ECS section of the service into passenger use.
Showing it as a Southampton service at Waterloo ought to confuse a few passengers, I expect...
gnolife
4 Nov 2010
Johnstone
Would it not show as Fareham or St Denys or somewhere like that, depending on the stopping pattern, a bit like what FGW do with the Oxford and Reading stoppers?
You'd expect so - maybe change the PIS at Guildford or somewhere? Probably easiest just to continue showing Havant on leaving Waterloo, as the normal service to Fareham goes the other way, and it's non - stop Fareham to Southampton anyway...
