Market Harborough Station Upgrade
Flying Phil
18 Apr 2016
Levels built up on Southbound platform and foundation re bars going in on Northbound around the footbridge. The stairs are going in over the next two weekends and tarmac for platforms to the North of the footbridge over the next two weeks. They are busy putting the platform edging slabs in today. So good progress with the fine weather helping.DSCF8296.JPG DSCF8297.JPG
59CosG95
18 Aug 2013
Beeston (Notts)
So, the big question in light of yesterday's wiring announcement - has there been any sign of OLE foundation piling behind the new alignment?
hwl
5 Feb 2012
If I were doing it (I'm not) I'd wait till the station was finished on the new alignment and then when the existing track and platform have been lifted/ demolished and the car park works expansion works are to start then pile on that side for TTCs.
Much simpler and cheaper to sort electrification work after the rail part of the station works are done.
Hence I wouldn't expect to see anything soon.
PS thanks as always for the electrification updates.
59CosG95
18 Aug 2013
Beeston (Notts)
Indeed - though the foundations may well be concrete cast in-situ behind the platforms, which may well be done during the blockade. We'll just have to wait and see!
PS Not a problem with the updates - I'll get the next MML one up very soon!
They aren't affecting the operational railway and doing them during the blockade probably risks the respective contractors getting in each other's way as well as increasing the amount of work to be done in a fixed length of time. Even if authorisation is in place to spend money by then (highly unlikely) it would be better to do them at leisure once the platforms are complete.
hwl
5 Feb 2012
Completely agree. The piling or bases can easily be done later in normal construction hours while the railway is operating.
Flying Phil
18 Apr 2016
I did ask at the site a while ago if there was any provision for electrification in the new platforms and was told "No - but it was future proofed, so easy to add later".
No chance, as the final final decision has yet to be made (although it is very likely to happen). The announcement yesterday wasn’t an announcement. It was an answer to a question - a very different thing in politics!
I’d have thought adding portals later with the verticals behind the platforms was a better solution than planting them in the platforms. The less obstructions on the platform the better, they are likely to be the minimum width allowed over at least some of the length...
Flying Phil
18 Apr 2016
Agreed - but perhaps I should have written "with the new platforms" rather than "in the new platforms".....:oops:
Flying Phil
18 Apr 2016
On the local news today they are reporting problems with the refurb of the Great Bowden road over-bridge, which is to the North of the station. The road is going to be affected for much longer - another few weeks it seems.
Flying Phil
18 Apr 2016
We now have one set of steps! Work continues on the platform infilling, and there is the base tarmac laid on the North half of the platforms. The second photograph is taken where the rails will be going Northbound.
Flying Phil
18 Apr 2016
They have restarted work on the Little Bowden foot bridge and on the Great Bowden road over-bridge, they are building new, higher, blue brick parapets, with the North side being built first.
And before anyone asks, while they may be OLE-compatible parapets they don't mean OLE is coming this far north. It's probable that moving the tracks around under the bridge has triggered a need to bring it up to current standards.
Flying Phil
18 Apr 2016
We now have steps on both sides of our new footbridge....and the Northbound platform has edging all along so vehicular access to the new trackbed and Southbound platform is only from the ends now. DSCF6503.JPG
class26
4 May 2011
But according to Aprils Modern Railways electrification WILL come as far north as MH
According to the headline and front cover splash. The actual article quotes NR "As part of our next funding cycle (Control Period 6) we are looking at the viability of options which would enable eletric trains to run from Market Harborough to London." It states DfT has announced the electrification but a search of DfT press releases shows nothing.
So it's not at all clear whether this is genuinely agreed or just a piece of spin, and I'm concerned that what ought to be an authoritative trade publication may be reporting it as something it isn't.
Chris125
12 Nov 2009
Isle of Wight
https://www.railjournal.com/passeng...ain-line-electrification-extension-confirmed/
NR have determined that it's the best way to provide the power supply and has been instructed to design it, but AIUI final confirmation has to wait for that to be completed - presumably in case they've misjudged the cost and it's no longer value for money.
richieb1971
28 Jan 2013
Just went past on a HST. Double tracks are down north of the station. Looking good.
DanDaDriver
5 May 2018
Had to laugh when I found out the previous 40mph crossover is being replaced by a 25mph one. And the south end signals are also not viewable from the platform. Cracking job by NR as always....
InTheEastMids
31 Jan 2016
Given the engineering siding is gone, no trains are turned back at MH and they normally shut the railway for engineering works rather than use bi directional running, I'm a bit surpised that there will be a crossover at all?
Re signals... Are they obscured by the new bridge or just that they need to be realigned during the shut down at the end of may?
DanDaDriver
5 May 2018
The signals are moving. I believe theres maybe going to be a banner repeater, but no AWS, which obviously brings its own risks.
Flying Phil
18 Apr 2016
I would have thought that the signals will be much more visible when the new platforms are in use, as it will be a straight track then - not the "S Bend".
Flying Phil
18 Apr 2016
Work is continuing on cladding the new footbridge and getting ready to install the lifts, preparing the platforms for top surfacing and preparing the trackbed for initial ballasting.DSCF6515.JPG DSCF6516.JPG
Apologies for the composition on the last picture, the camera has to be held over a 7 foot tall fence!
