map of what specific lines use what signalling system?
popeter45
7 Dec 2019
london
do any online maps exist to show in more than per nation what signalling systems are used per line?
e.g. to see where the Danish signalling ends and Swedish begins or Signalling specific to certain areas (e.g. Cambrian line ETCS)
23 Nov 2015
Many of the country infrastructure operators include maps of this sort in their annual Network Statements. For example, that for Belgium can be found on the Infrabel site, here: https://infrabel.be/en/networkstatement
There's then links to the main statement and also various appendices, including maps. Each country will vary in the format, as you'd expect. The Belgian one is pretty good as it colour codes the map by TBL1, TBL1+, TBL2, TVM430, ETCS etc.
itfcfan
7 May 2011
OpenRailwayMap unfortunately only has little information about train protection systems in the UK...
link
As you say, sadly not much coverage of train protection systems in the UK. However, all source data is taken from openstreetmap.org and its easy to add information there. For anyone with knowledge of the lines, please consider doing it. Information on the openstreetmap.org "tagging" (classification of locations) for railway lines here:
https://wiki.openstreetmap.org/wiki/OpenRailwayMap/Tagging#Train_protection_systems
Edit in your browser using the URL below (an account is free to create and only requires an email address):
https://www.openstreetmap.org/edit
JonasB
27 Dec 2016
Sweden
I don't have an answer to your question, but the border between the Danish and Swedish systems are on Pepparholmen.
43096
23 Nov 2015
link
Worse than that, what it does have is wrong. The Great Western Main Line does not have ETCS to Bristol.
