On Sunday 30th June I have an advance from Southport (dep 19.38) to Rochdale. This train calls at Rochdale direct, however my itinerary has a change at Manchester Victoria arriving at 20.49 onto a Leeds train dep 20.54, so just 5 minutes which I presume is the minimum?
RTT show the Southport train arriving at 20.50 which I assume would then provide an invalid connection time. Nonetheless, working on the assumption that 20.49 is correct, then what are my options should the train arrive at Victoria a couple of minutes late? Am I still obliged to try and make the connection (probably P6 to P1 negotiating the stairs and overbridge) and potentially missing the connection and then be left with insufficient time to rejoin the original train I had alighted from; or can I simply stay on my original train because a sufficient interchange time was then unavailable?
Thanks in advance.
Thanks in advance.
