Manchester Recovery Taskforce (timetable) consultation
then compare Birmimgham, Leeds, Manchester, Glasgow ... and weep.
Birmingham, Manchester and Glasgow I'll give you - through historic quirks they each have two major city centre stations. But in each case it's difficult to see how anything could really be done about that today?
Leeds is probably the best example of how to combine everything into one station, and whilst it has its compromises, it's a pretty decent station in a lot of ways.
PR1Berske
27 Jul 2010
Picky picky :)
Yes, you have a point, but I meant more in the sense of "large mainline station with appropriate facilities which would become an equal to Piccadilly, rather than just where all the 1980s DMUs go to fume-belch" - a bit like the two Glasgows, perhaps.
I never thought about the "two Glasgows" as a reference for Manchester. A good way to think about how to separate the two of capacity allowed.
Killingworth
30 May 2018
Sheffield
Personally I think both the Cleethorpes and Nottingham services should terminate a Piccadilly. Castlefield just doesn't work as a long distance intercity line.
Cleethorpes is terminating there now, rather than splitting and half going to the Airport. There wasn't enough platform space at the Airport to send all 6 cars through when trains were increased from 3 to 6 car. 6 weren't needed to the Airport but splitting added another complexity to an already tight timetable. I'd be happy to see that service terminating in the main shed. Sending it on to Liverpool adds far more risk to timekeeping, particularly eastbound.
One through Liverpool train from Sheffield is desired, provided it's timekeeping is improved.
We have another factor to consider. The Manchester/Northern Hub projects included the smallest and all but overlooked element, the Hope Valley Capacity Scheme. That work is about to start with completion by September 2023. Minor timetable changes to current services could happen in December 2023. In May 2024 a third hourly fast service is due to start between Sheffield and Manchester, post Covid reviews permitting.
There's no room to feed it through Castlefield and tracks to Victoria and beyond Victoria are also congested. The main shed is the only place it's likely to start. I can see it being an extended New Mills stopper extended to Sheffield semi-fast to save Piccadilly space and paths out through Stockport!
Xenophon PCDGS
17 Apr 2011
Has the Cleethorpes service ever had any official thoughts on going via Denton to Manchester Victoria and then onwards from there to Liverpool? That way would still see Stockport being served and all the units are diesel powered on that line.
Killingworth
30 May 2018
Sheffield
That would go down as an even bigger lead balloon in Sheffield and the east than axing the direct Airport service!
As far as most of us are concerned Piccadilly is the place we want to go for more interchange options, including the Airport.
Far too slow, causes conflict at Heaton Norris Junction and Chat Moss has plenty of services already. It has come up a number of times in discussion - it doesn't seem to get raised in any official sense.
Ianno87
3 May 2015
Far too slow, causes conflict at Heaton Norris Junction and Chat Moss has plenty of services already. It has come up a number of times in discussion.
"Here's an obscure line, we need to find a use for it" is the logic.
PR1Berske
27 Jul 2010
I mentioned this on a Facebook post. There is something symbolic, maybe psychological, about the Airport link that some towns and cities have. It's hard to do the PR about losing something even if a new link is established to Liverpool
The conflict at Heaton Norris is hardly unmanageable, and is really no worse than the conflicting move you need at Slade Lane or Ardwick Jns, if continuing to Castlefield. Reducing the frequency through Castlefield means that, overall, it would be a boon for reliability, whilst also providing some cross-city connectivity.
So I think it would, in a number of ways, be a more sensible approach than losing any semblance of a reasonably fast service from Liverpool to Manchester Airport.
But it's very unlikely to happen.
Ianno87
3 May 2015
The junctions in isolation are fine. Creating a plan for a single junction is easy.
It's the fact that one affects the other is the problem.
Greybeard33
18 Feb 2012
Greater Manchester
...In May 2024 a third hourly fast service is due to start between Sheffield and Manchester, post Covid reviews permitting.
Option B+ does appear to free a path between Piccadilly and Stockport. Namely that currently used by the Blackpool - Hazel Grove service, which would be diverted to terminate at the Airport.
I wonder if there might be an unstated intention to reserve that path for the third fast Sheffield - Manchester service....
Didn't CrossCountry found a few minutes of journey time improvement out of it? That would have to be taken away again...
I don't get this obsession with turning back the clock.
Because Castlefield (just about) worked back then, and the opening of Ordsall knackered it. You can't blame people for wanting to go back to something that worked, and for having a lack of confidence in the people who (totally predictably) broke it not to break it again.
Ianno87
3 May 2015
Because Castlefield (just about) worked back then, and the opening of Ordsall knackered it. You can't blame people for wanting to go back to something that worked.
But had less passenger benefits than could potentially be the case with another approach.
They are saying they will only agree if the reductions are temporary and a way is found to reverse them ASAP
Well the planning for the timetable change in December 2022 needs to start now. So either they agree that the industry plans now on the basis of the ‘reductions’, ie the preferred option, or they will get something akin to the current level of service, which is rather less than the preferred option.
And, if the industry is planning now for the preferred option, and TfNs conditions are not met, then What happens? Back to the current timetable?
Xenophon PCDGS
17 Apr 2011
Possibly, though I continue in my strong view that Manchester Airport is the tail wagging the dog (particularly post COVID) and is still overprioritised.
When discussing Manchester Airport, remember all the associated new business and commercial sites within its environs that the Chinese were interested in and also the fact it is a two-runway airport. Have you viewed the airport and its environs in recent times?
I don't see how it could be - unless the "fast" service is to stop at all the local stations between Hazel Grove and Manchester.
berneyarms
26 Nov 2013
Dublin
Do you not think that service would surely be replaced by a Piccadilly-Hazel Grove stopper?
tbtc
16 Dec 2008
Reston City Centre
The whole thing is just a complete mess. Everyone in the North wanted a direct rail link to Manchester and Manchester Airport. The only good to have come from this debacle is that this experiment has now been tried and proven it cannot work and a reasonable tph rate through Manchester can now be agreed. It has failed to offer a reliable timetable so much that it has actually led to some previously profitable commuter routes and stations losing far too many passengers.
Good points - I think that we need to have a tough conversation about just how many services can be accommodated by finite number of paths
I expect another storm of protests when this is put out to public consultation.
I think that the authorities need to accept that any tweaks will generate petitions and negative tweets etc, given how well organised people are these days - need to bite the bullet though
Speaking from Sheffield, I agree.
I can't say I'm thrilled by all Hope Valley fast services going through 13/14 and Castlefield to/from Liverpool. Firstly I'm yet to be convinced that that will greatly improve the reliability of two long distance services. Secondly the time to get from the entrance of the station to crowded and unattractive platforms 13/14 adds a couple of minutes to overall journey time.
But we have to give this a try. At least both fasts will depart from the same place. However, Northern's 195 stopping services may get extra through business, not least because their fares can undercut the other two by 50% or more! Loadings are already back to pre-Covid on many of their trains.
I think that the idea of a half hourly Sheffield - Liverpool service is something more desired on Merseyside than in South Yorkshire - there seems to be a lot more focus on "how many long distance links does Liverpool have compared to the number that Manchester has" - I'd be okay with everything from Sheffield terminating in the main Piccadilly shed (any through service to Castlefield/ Airport/ Liverpool/ Blackpool/ Windermere etc would have some benefits but also some costs)
The current Southport to Manchester set-up needs improvement, not least because missing a train from Piccadilly entails either making it to Victoria or hoping you can catch a connection at Salford. One destination for all Southport services makes sense on this basis, on paper.
Agreed - whilst I appreciate that a lot of enthusiasts like complicated/ messy combinations of random patterns of services, I'd suggest that everyday commuters would prefer something simple and reliable (instead of worrying about which direction they should have to head in for their train home)
I'm all for the S-Bahn idea
That does not appear to be the overriding desire of the Sandgrounders and other users of the line (as represented by OPSTA). The preference appears to be "one of each" as has been the established pattern since the late 1990s, and before that it was still split in a sense with an all-day hourly-ish service running to Picc and beyond and peak extras to/from Vic. Only pre Windsor Link (early 90s?) was it all to Vic as Picc could not be reached.
You can, as you say, always take a connection if you miss it and can't be bothered walking over to the other station.
Nominally the "both to Vic" thing does make sense, but it seems a fair whack of the Southport line users have built up their journeys based on direct services to Castlefield (e.g. working at or attending the university) and the additional journey time on a commute would never be appreciated. And most people don't regularly miss trains on infrequent services, they check the timetable and act accordingly. It's not like a "walk up" type service like Merseyrail.
Tell me again about your suggestions that other people around the UK lose their long established bus services into city centres (and should be forced to change onto a tram/train), and other people should have their train services "simplified" to match some Germanic definition, but the precious people of your childhood line must have their timetable preserved because they can't be expected to change trains...
What would be far more beneficial would be a high frequency corridor service and people use it like using a metro. For example all Stockport services terminate in the main train shed (including the Sheffield fasts), but then we have no more than two dedicated services passing through Castlefield - one towards Bolton (and onwards) and one towards Victoria (and onwards). That would help far more people, knowing that once arriving at Piccadilly, you’ll have no more than a 5-10 minute wait until you connecting train.
Agreed - keep it simple
If all the Airport services ran through 13/14 and all the 13/14 services ran to the Airport then you'd remove a lot of conflicts and allow a much more balanced service (rather than nine trains per hour on the Airport branch but with gaps of up to seventeen minutes because of all the different long distance links, which means that the local stations on the line can't have a regular service into Manchester)
It's a shame a city growing at the scale Manchester is, doesn't get the transport infrastructure spending it deserves.
Adding more lines through castlefield through to Piccadilly and adding platforms 15&16 would be ideal but won't happen.
What does Manchester "deserve" though?
London manages dozens of services per hour on the two track Thameslink infrastructure
London will manage dozens of services per hour on the two track Crossrail infrastructure
Manchester could manage dozens of services per hour on the two tack infrastructure through Castlefield - but not if they want to have a messy combination of routes like Newcastle/ Middlesbrough/ Glasgow/ Edinburgh/ Barrow/ Llandudno - Manchester Airport, Liverpool - Norwich, Liverpool - Crewe, Blackpool - Hazel Grove... (as well as proposals for routes like Bradford - Manchester Airport in the Northern franchise that Arriva committed to delivering)
How much longer can people argue. #1313 1314 now on this thread alone. It's never been possible to please everyone. How much more so-called consultation? I recognise it takes time to build and implement a new timetable. A/ B/ B+/C ... C++ ... ? Consistency, reliability, those are the objectives. Let's get on now.
We'll keep arguing, because everyone thinks that their line is special and deserving of regular services to Castlefield/ Manchester Airport etc - someone has to try to trim things down and simplify things - I don't envy them that task, since they are going to annoy a lot of people one way or the other
Greybeard33
18 Feb 2012
Greater Manchester
The published list of South Manchester services for Option B+ does not include a Piccadilly - Hazel Grove stopper. But I suppose it might have been accidently omitted.
Edit: In the Rail North Committee meeting, Andy Burnham mentioned the reduction of Hazel Grove services from 3tph to 2tph as one of the issues Greater Manchester has with Option B+. This confirms that the 2tph to Buxton would be the only off peak services to Hazel Grove.
berneyarms
26 Nov 2013
Dublin
I'd be pretty sure that it has to be an omission. They are hardly going to reduce the service to Hazel Grove to hourly.
craigybagel
25 Oct 2012
Option B+ includes 2tph to Buxton, thus also giving Hazel Grove 2tph. There's also a 1tph Piccadilly - Hazel Grove in the peak.
Purple Orange
26 Dec 2019
The North
You can’t compare London & Manchester in that way. Manchester still needs services to Newcastle, Scotland, North Wales etc but unlike London it doesn’t have the required terminal capacity.
Rhydgaled
25 Nov 2010
I like the principle, and I think far too much emphasis is placed on giving everywhere a train to Manchester Airport. We're facing a climate emergency for heaven's sake, if there's that much demand for airport services we're in big trouble (oh, we are).
Unfortunately the suituation is complicated by the fact that there are some useful links (a big one being Sheffield-Liverpool) which cannot really be delivered without making one or two exceptions to the 'all 13/14 services go to the airport' rule but those exceptions should be minimised if you ask me. If the only service allowed on the Ordsall chord was a 15-minute interval Northern stopper to the airport, I wonder if that would be sufficient to make Victoria and Piccadilly act as one station for interchange purposes, removing one argument for services like TPE's WCML operation to serve Piccadilly. That or increase the frequency of the trams between the two main Manchester stations as I've suggested previously on this topic.
Another problem of course is that, if you deconflict services to avoid spreading delays between service groups you end up having to run more through services through Victoria and instead importing delays from one side of Manchester to the other. For example, if you sent the TPE WCML trains, the Llandudnos and Chesters etc. into Victoria you might run out of turnback capacity at Stalybridge and end up with things like Glasgow-Manchester-Hull and Llandudno-Manchester-Newcastle, which I think could be useful services but perhaps not ideal from a timekeeping perspective.
Not quite everyone, 'my line' doesn't really factor into this at all. I'm very much 'out of area' but if I was to go from here to Manchester I would probably be coming in from Shrewsbury on the TfW Milford Haven / Carmarthen / Swansea to Manchester service, and I'm perfectly happy that terminating at Piccadilly thank you. No need to send it to the airport.
wobman
2 Jan 2011
There is some strangle ideas here, what TOC will run the Newcastle to Llandudno ? Is that to replace TFW services ??
Have you seen the congestion on the M56 to Manchester airport, that's why TFW and DFT wanted the connection & the conflict moves with ATW units stabling in the Mayfield loop. There's a demand for direct services to the airport by some customers, if there wasn't why do the services pre covid get so busy ?
TFW south Wales to Manchester services terminate a Piccadilly, it's the the N Wales coast services that go onwards to Manchester airport.
The present plan B+ is the way forward by the looks of things and it's the best compromise for most stakeholders involved.
Dspatula
19 Dec 2019
Manchester
There's not that much actually missing from the day time timetable compared to 2019, the Newcastle airport and the Glasgow outside of the peak are main two, with some Norwich trains missing for different reasons. So 12/13 trains in alternating hours each way and just 12 each way in the peaks. The new timetable isn't much different with one through train to Piccadilly cut and an additional terminating train in the peaks. So at Oxford 9 through 1 freight 2 terminating +1 peak terminating compared with the current 9.5 through 1 freight 2 terminating +0.5 peak through
Mostly just destinations south of Manchester changed I will say though that cutting the Liverpool Crewe to the airport, along with moving the Hazel Grove there and cutting the Alderley Edge through train will reduce a large amount of crew changes at Oxford Rd as Liverpool, Wigan, Vic, Blackpool and Barrow all sign as far as the airport, so a lot of reliability gains to be made there.
