Manchester Metrolink (Non speculative discussion)
Tetchytyke
12 Sep 2013
Isle of Man
It would be interesting to know if the Etihad deal includes any benefit for Metrolink, such as the cost of re-naming the station and changing everything that references that name, both at the start and when the deal ends.
AFAIK Etihad don't sponsor the tram stop, that part of SportsCity is called Etihad Campus because Manchester City own it and because Manchester City pull all sorts of financial shenanigans to do with sponsorship (115 shenanigans, to be exact!)
I can't imagine that Metrolink would get any benefit from the naming, and I'd also imagine that Metrolink would be on the hook for the cost of changing the name if Etihad/Man City ever leave.
I’m pretty sure Trafford Palazzo has a code linked with Event City but I am unsure about that one
Yeah, the code is EVC, even after all the various re-naming that particular stop has had.
The stop name just refers to the location, as is the case with Abraham Moss.
However, if Etihad end their sponsorship and someone else comes in, then either someone has to find the money to change the stop to match the new stadium name, or it stays the same and becomes increasingly confusing as people forget the reason for it.
Mcr Warrior
8 Jan 2009
Wasn't exactly a major problem when 'intu Trafford Centre' tram stop had its name changed to 'The Trafford Centre' in early 2021.
Tetchytyke
12 Sep 2013
Isle of Man
Changing the station signage and re-programming the PIS wouldn't cost very much. And I'm sure a new sponsor of the sports facility (should Man City ever leave or change ownership) would be easily encourages to give a bit of money towards the cost.
For the internal systems I'm sure they'd just leave the code as it is (SPC- SportsCity) just as they have with Trafford Palazzo- that station is now on its third name in six years but the internal code still reflects its original name.
Xenophon PCDGS
17 Apr 2011
Not wishing to rain on anyone's parade, but noting the size and capacity of the existing stadium used by Manchester City, why on earth should they relocate from there? They also have the smaller stadium across the road from there.
Starmill
18 May 2012
Bolton
Indeed, the codes aren't needed for anything customer-facing.
RikGarner
18 Apr 2018
The frustrating thing for me is that I saw no communication about the frequency changes. I travel on the network every working day and I had no idea of the changes. I came back from a week off to be confused about why the Bury trams took so long to show up at Piccadilly. It was only coming here I discovered what was going on.
Shoddy from TFGM.
Class 466
5 Mar 2010
Atherton, UK
Shoddy from TFGM.
Every time they posted about it, it was buried in news articles about infrastructure investment or engineering works coming up. Rather than posting an upfront statement online solely about the frequency changes and then using the information boards at stations to publicise it - which pretty much any other public service operator would do.
lowe1409
6 Feb 2024
Cheshire
Maybe they was hoping the average user wouldn't notice the difference between 12 and 15 minutes? On paper it's a very minor change on the face of it being only 3 minutes.
Class 466
5 Mar 2010
Atherton, UK
Some stops saw their frequency drop from 6 minutes to 15, that is a huge change.
lowe1409
6 Feb 2024
Cheshire
True, but admittedly that change was better communicated when they redrew the map to exclude the Etihad to mediacity line. I feel it was only fairly recent those additional services started back up wasn't it?
lowe1409
6 Feb 2024
Cheshire
The Altrincham to Piccadilly service goes to Etihad Campus all day now so they haven’t seen the same drop off
Altrincham to Piccadilly trams have been extended to Etihad Campus, so that stretch still has two lines serving it.
Makes sense I guess. Feels weird that branch gets to keep it's additional service over the other. I feel it's always been the quieter of the two branches. Though I guess it is an easy extension
507 001
3 Dec 2008
Huyton
I think Anchorage and Salford Quays do too as they were also renamed just before opening.
ANC and SFQ respectively. If the codes were ever wrong for these stations it was corrected long before I started as a Driver (more than a decade ago).
This is the exact reason why the name wasn’t changed in any internal systems/documentation. The Etihad campus name boards on the station itself only have stickers over the original Sports City name.
Rail Ranger
20 Feb 2014
More engineering work is taking place on Metrolink from Monday 1st June to Tuesday 9th June (inclusive). The line through Market Street and Shudehill will be closed. This is a summary of the changes:
All services from Altrincham will operate to Bury via Exchange Square.
Services from the Trafford Centre will operate to Etihad Campus.
Services from Manchester Airport will operate to Victoria via Exchange Square.
Passengers from the Altrincham and Bury lines will be able to change at St Peter's Square to get to Piccadilly station (on an Etihad Campus or Ashton tram).
More information can be found here:
Tram improvement works and disruptions | Bee Network | Powered by TfGM https://share.google/WgfbSuhQKDb6eORbE
pdsalford
14 Mar 2014
They've not done much work at Piccadilly Gardens this week, other than sit and watch somebody wielding a mallet. It was closed for 2 months last year, again this year, when will they finish any work?
Tramfan
19 Mar 2011
When did that get added? I was planning a visit there next week, but was trying to avoid all the engineering work
Howardh
17 May 2011
There's a replacement bus Piccadilly/Victoria as well! Looking at the map is appears to call at Shudehill.
Rail Ranger
20 Feb 2014
It's been planned for quite a while. The only section that will not be operating is between Piccadilly Gardens and Victoria.
The dedicated Metrolink replacement bus between Piccadilly and Victoria will only be operating during the periods when the normal free bus between Piccadilly and Victoria is not running.
Howardh
17 May 2011
Thanks, they should mention that on the map! Under normal conditions a direct bus service Vic-Picc would be useful, I find the tram and free bus take a long time!
Rail Ranger
20 Feb 2014
Also there will be a complete closure of the Altrincham, Eccles and Trafford Centre lines from Monday 13th July to Sunday 2nd August (inclusive) due to track relaying at Cornbrook and Deansgate-Castlefield.
