Manchester London Glasgow Manchester.
23 Apr 2012
Greater manchester.
Hi to all, I am heading to London in February to see the Abba concert. I will be travelling from Manchester on a Tuesday and heading to Glasgow the following day - Then returning to Manchester on the Friday. How would I book such a ticket?, I could buy singles but that might be too expensive, I have used the Forum ticket site many times, Any help would be appreciated.
pokemonsuper9
20 Dec 2022
Greater Manchester
Depending on how early you book, advanced tickets may be the cheapest option (and take a look for splits, might save you some money).
If you don't want to use advanced tickets, people with better knowledge will probably respond with time.
Farigiraf
23 Jul 2023
Bridge on the River Cam
If you travel via Crewe you could get a Manchester-Crewe ticket, a Crewe-London return and a Crewe-Glasgow return although most Avanti West Coasts to Glasgow have their first stop at Warrington, unless you get a Crewe-Glasgow return via TPE and finish short on the way back
Haywain
3 Feb 2013
Perhaps start with a return from Preston to London and start short at Manchester, and add a Preston to Glasgow return. However, booking early may see Advance tickets coming out cheaper. Or even a Glasgow to London return and add a Glasgow to Manchester single.
pokemonsuper9
20 Dec 2022
Greater Manchester
Wouldn't that also need a Preston -> Manchester ticket for the final leg?
Shotton
10 Jun 2019
If advance tickets are being used, Avanti Superfare may be an option. These are very cheap fares, but you are not able to choose which train you travel on, only the date - afaik you can choose morning/afternoon/evening, so should be able to ensure arriving in time for the concert.
These would be available for the Manchester -> London (£20) and London -> Glasgow (£30), however are only bookable between 7-21 days in advance, and you would need a normal advance for Glasgow -> Manchester.
Alternatively, for a flexible option, you may want to consider the off-peak (£50.40, valid arriving Euston after 09:59, and returning after 08:45) or super-off-peak (£39.20, but very restricted, and probably not worth it in my opinion) return from Manchester -> London routed LnW/TfW only, and then combine this with a Manchester -> Glasgow off-peak return (£99.50 routed via Carlisle, and essentially unrestricted). This would require travelling via Manchester on the London -> Glasgow leg and using the TfW service to/from Crewe and LnW to/from Crewe to London and would come to ~£140 - £150 total.
If you wanted to save some time, you could travel on the LnW service to Crewe on the return, stop short on your Manchester to London ticket and buy tickets Crewe -> Carlisle off-peak return (£80.20, routes via Preston and again essentially unrestricted) and Carlisle -> Glasgow off-peak return (£30.90, and only valid after 09:00, if you needed to travel beforehand, the almost unrestricted off-peak return from Crewe to Glasgow would be cheaper than a combination at £130). This option would come to ~£160-180, and would still probably be significantly slower than direct Avanti services.
For an itinerary that allows the use of the fastest services, I can't think of much better than what was suggested above - off-peak return Preston -> London (£110.70 valid arriving into Euston post 11:29, and not valid leaving Euston between 15:00 and 18:45, so significantly more restricted than the LnW/TfW option), off-peak return Preston -> Glasgow (£89.40, essentially unrestricted) and anytime day single Preston -> Manchester (£14.50) giving a total of ~£215.
Anytime tickets all seem extortionate, so I would not recommend them unless you really can't avoid it. And, of course, someone may well be able to advise of better options then I can. At any rate, in my opinion normal advances (not Superfare) would still be likely to be better value than all the flexible suggestions I made.
23 Apr 2012
Greater manchester.
Thank you so much for all of your replies, I really appreciate you taking the time to help me. Well there are certainly a lot of options and I will have a look and see what comes in cheaper. Thanks.
anothertyke
23 Jun 2023
If price is your main determining factor, I'd be looking at one of the low cost airlines for the London-Glasgow leg. The option and date I looked at on a Wed in Feb with no checked bag came in at £26, so say £60 including ground transport.
glasgowniteowl
25 Jan 2019
Would a London to Haymarket return work out fairly reasonably for the London to Glasgow then the Glasgow to Manchester legs? Just then need the first leg Manchester to London
Mcr Warrior
8 Jan 2009
Off Peak Returns, (route "Any Permitted") are, however, still possible from London Terminals (which includes London Euston) to/from Glasgow Central/Queen Street.
Hadders
27 Apr 2011
Break of journey is not permitted on the outward portion so you're not allowed to start short at Manchester Piccadilly.
Mcr Warrior
8 Jan 2009
That wasn't contemplated. Single ticket for the initial Manchester Piccadilly to London leg, then the Off Peak Return from London Terminals to Glasgow CEN/QST, using the return portion to get back to Manchester.
plugwash
29 May 2015
Yes, it would.
Are you sure about that?
The routing guide tells me that map combinations for Glasgow to Crewe are CG GK+CG
Map CG appears to allow travel from Glasgow to Crewe via Manchester.
Haywain
3 Feb 2013
I am sure - I was not talking about a Glasgow to Crewe ticket.
I think you are talking at cross-purposes :)
@Haywain was suggesting the use of a Preston-London as well as Preston-Glasgow ticket, with a Preston-Manchester single for the last bit of the train back from Glasgow to Manchester.
A Crewe-Glasgow return in combination with a Preston-London return would cover all travel, but would cost more than adding on a Preston-Manchester single to Preston-London and Preston-Glasgow returns.
