Manchester - Euston Via Stone (Help)
xtradj
24 Jul 2006
Just intrigued really.. dont know how it works now..
but from Dec 14th theres 3 trains an hour to euston from manchester
1 via wilmslow, and the other 2 via stoke
the 2 via stoke, do they branch off at stone straight onto the trent valley line, or do they follow into stafford then onto the trent valley
im guessing they branch off at stone? and the 3/4 sheduled to stop at stafford from manchester to london, go through to stafford then onto the trent valley?
just wondering any one know?
xtradj
24 Jul 2006
cheers mate thought so
good to see Stone being used again though by london midland
Gizmogle
28 Aug 2006
What? They're using the station now? I didn't know that.
What about all the other stations around there with no service?
Benn88
29 Oct 2008
Norton Bridge is now inacessable as a rail link as they have removed the footbridge to the island platform, although it is still regarded as open because they run a poxy bus service aparently... Farce.
Norton no Bridge, will never see a train again. If you realise how difficult it is to close a station then any workaround will do.
Jordy
9 Jun 2005
WCML South
Rugeley Trent Valley, Lichfield Trent Valley Low Level, Tamworth Low Level and more importantly Atherstone (which had a diabolical service) will all greatly benefit from the new London Midland timetable with hourly trains to London and Crewe via Stoke.
87015
3 Mar 2006
GEML/WCML/SR
I'd argue Rugeley residents are worse off as travel to/from Stafford - Rugeley Town (TV station being well placed for not a lot) will now require a change at a windswept hovel with no facilities and practically no service information. Its a nervy plus 10 in both directions - anyone who travels with London Midland regularly will know how often that is likely to miss!
They don't branch off at stone, they continue along the Stoke Lines to Colwich Jn, where they join the Trent Valley line, thus avoiding Stafford.
If they are shown as calling at Stafford then they branch off the Stoke Lines at Stone and join the short branch to the Trent Valley at Norton Bridge.
Edit:
Before WCRM, the time penalty for branching off at Stone was approx 6 mins, this was due to having to slow to 25mph for the very tight curve at Stone and 30mph to join the WCML at Norton Bridge, plus the 85mph restriction for the curve just south of Stafford and the longer distance. This compares unfavourably with remaining at 95mph until Colwich then slowing to 55mph.
I'm not sure exactly what effect WCRM has had, but I'm pretty sure the junction at Colwich is a lot faster than 55mph now, while the junctions at Stone and Norton Bridge are little improved if at all, so the time penalty may be greater than 6 minutes these days. Of course, that's without a stop at Stafford - a brief call there and the time penalty would be around 10 minutes.
