102 fan
- Joined
- 14 May 2007
- Messages
- 790
What time does it take to walk from terminal 1 in Manchester Airport to the railway station?
And another if the moving walkways aren't5 mins if using escalators, 10 mins if you need to use the lifts. (3 level changes along the way). Add a couple of mins if you're a slow walker.
Never work and airport won't spend money on the repairs to get them going !And another if the moving walkways aren't![]()
If you are tight on time to catch a train, my advice is to install the trainline app or similar on your phone. Or have your train tickets already.What time does it take to walk from terminal 1 in Manchester Airport to the railway station?
The walkways aren't ever being fixed as apparently the parts are obsolete now
Much like the Airport!!
The station showing signs of age as well.....
I use TPE ...Nectar points as well! And no booking feeIf you are tight on time to catch a train, my advice is to install the trainline app or similar on your phone. Or have your train tickets already.
I've seen massive queues for the ticket office and ticket machine.
It is a shorter walk from ‘The Station’ as it is signposted, to Terminal 1 than it is to Terminal 2 and the newly modernised section of Terminal 2 is at the far end, making it an even further walk!Given they've just modernised terminal 2 they should at least get the link between terminal 2 and the station replaced. They're claiming they are going to be one of only a handful of airports to be able to offer pre-departure USA clearance but can't even get moving walkways working!
I've found they seem to be the only airport where empty bottles/flasks and plugs can cause bags to be rejected in the security area. And the staff don't tell you to remove those items pre-scanning either. They obviously expect people to take through empty bottles, given the location of the bottle refilling facility just after security.
