Malaysia Airlines MH370 "Lost Contact"
Robertj21a
22 Sep 2013
Australia is reporting some fairly large (24m) debris sighted by satellite in Indian Ocean - planes and ships on way. Emphasising that it may not be connected with the missing flight.
Robert
fowler9
29 Oct 2013
Apparently HMS Echo is down there now. Saw her at the pier head in Liverpool last year. Not what looks like a typical warship but very aptly named being in Liverpool and apparently very capable for what she does.
Yes she's part of the Hydrographic Squadron which is a nifty capability that the Royal Navy has. There's some good links showing of the kind of thing she does here. Very useful along with her sister HMS Enterprise and their larger counsin HMS Scott which is an ocean survey vessel. They all have a secondary mine hunting capability.
I'm not sure what the maximum depth of water that HMS Echo can operate her survey equipment in but if it isn't to deep I imagine she'll be surveying the seabed for sign of debris. Otherwise she's another pair of eyes.
YorkshireBear
23 Jul 2010
I am not one for constantly spreading rumors but i have just been sent this link by a friend. Refreshing to hear something that actually sounds relatively feasible.
http://www.wired.com/autopia/2014/03/mh370-electrical-fire/
There has been a lot of speculation about Malaysia Airlines Flight 370. Terrorism, hijacking, meteors. I cannot believe the analysis on CNN; it’s almost disturbing. I tend to look for a simpler explanation, and I find it with the 13,000-foot runway at Pulau Langkawi.
We know the story of MH370: A loaded Boeing 777 departs at midnight from Kuala Lampur, headed to Beijing. A hot night. A heavy aircraft. About an hour out, across the gulf toward Vietnam, the plane goes dark, meaning the transponder and secondary radar tracking go off. Two days later we hear reports that Malaysian military radar (which is a primary radar, meaning the plane is tracked by reflection rather than by transponder interrogation response) has tracked the plane on a southwesterly course back across the Malay Peninsula into the Strait of Malacca.
The left turn is the key here. Zaharie Ahmad Shah1 was a very experienced senior captain with 18,000 hours of flight time. We old pilots were drilled to know what is the closest airport of safe harbor while in cruise. Airports behind us, airports abeam us, and airports ahead of us. They’re always in our head. Always. If something happens, you don’t want to be thinking about what are you going to do–you already know what you are going to do. When I saw that left turn with a direct heading, I instinctively knew he was heading for an airport. He was taking a direct route to Palau Langkawi, a 13,000-foot airstrip with an approach over water and no obstacles. The captain did not turn back to Kuala Lampur because he knew he had 8,000-foot ridges to cross. He knew the terrain was friendlier toward Langkawi, which also was closer.
Take a look at this airport on Google Earth. The pilot did all the right things. He was confronted by some major event onboard that made him make an immediate turn to the closest, safest airport.
The loss of transponders and communications makes perfect sense in a fire.
When I heard this I immediately brought up Google Earth and searched for airports in proximity to the track toward the southwest.
For me, the loss of transponders and communications makes perfect sense in a fire. And there most likely was an electrical fire. In the case of a fire, the first response is to pull the main busses and restore circuits one by one until you have isolated the bad one. If they pulled the busses, the plane would go silent. It probably was a serious event and the flight crew was occupied with controlling the plane and trying to fight the fire. Aviate, navigate, and lastly, communicate is the mantra in such situations.
There are two types of fires. An electrical fire might not be as fast and furious, and there may or may not be incapacitating smoke. However there is the possibility, given the timeline, that there was an overheat on one of the front landing gear tires, it blew on takeoff and started slowly burning. Yes, this happens with underinflated tires. Remember: Heavy plane, hot night, sea level, long-run takeoff. There was a well known accident in Nigeria of a DC8 that had a landing gear fire on takeoff. Once going, a tire fire would produce horrific, incapacitating smoke. Yes, pilots have access to oxygen masks, but this is a no-no with fire. Most have access to a smoke hood with a filter, but this will last only a few minutes depending on the smoke level. (I used to carry one in my flight bag, and I still carry one in my briefcase when I fly.)
What I think happened is the flight crew was overcome by smoke and the plane continued on the heading, probably on George (autopilot), until it ran out of fuel or the fire destroyed the control surfaces and it crashed. You will find it along that route–looking elsewhere is pointless.
Ongoing speculation of a hijacking and/or murder-suicide and that there was a flight engineer on board does not sway me in favor of foul play until I am presented with evidence of foul play.
We know there was a last voice transmission that, from a pilot’s point of view, was entirely normal. “Good night” is customary on a hand-off to a new air traffic control. The “good night” also strongly indicates to me that all was OK on the flight deck. Remember, there are many ways a pilot can communicate distress. A hijack code or even transponder code off by one digit would alert ATC that something was wrong. Every good pilot knows keying an SOS over the mike always is an option. Even three short clicks would raise an alert. So I conclude that at the point of voice transmission all was perceived as well on the flight deck by the pilots.
But things could have been in the process of going wrong, unknown to the pilots.
Evidently the ACARS went inoperative some time before. Disabling the ACARS is not easy, as pointed out. This leads me to believe more in an electrical problem or an electrical fire than a manual shutdown. I suggest the pilots probably were not aware ACARS was not transmitting.
As for the reports of altitude fluctuations, given that this was not transponder-generated data but primary radar at maybe 200 miles, the azimuth readings can be affected by a lot of atmospherics and I would not have high confidence in this being totally reliable. But let’s accept for a minute that the pilot may have ascended to 45,000 feet in a last-ditch effort to quell a fire by seeking the lowest level of oxygen. That is an acceptable scenario. At 45,000 feet, it would be tough to keep this aircraft stable, as the flight envelope is very narrow and loss of control in a stall is entirely possible. The aircraft is at the top of its operational ceiling. The reported rapid rates of descent could have been generated by a stall, followed by a recovery at 25,000 feet. The pilot may even have been diving to extinguish flames.
But going to 45,000 feet in a hijack scenario doesn’t make any good sense to me.
Regarding the additional flying time: On departing Kuala Lampur, Flight 370 would have had fuel for Beijing and an alternate destination, probably Shanghai, plus 45 minutes–say, 8 hours. Maybe more. He burned 20-25 percent in the first hour with takeoff and the climb to cruise. So when the turn was made toward Langkawi, he would have had six hours or more hours worth of fuel. This correlates nicely with the Inmarsat data pings being received until fuel exhaustion.
Fire in an aircraft demands one thing: Get the machine on the ground as soon as possible.
The now known continued flight until time to fuel exhaustion only confirms to me that the crew was incapacitated and the flight continued on deep into the south Indian ocean.
There is no point speculating further until more evidence surfaces, but in the meantime it serves no purpose to malign pilots who well may have been in a struggle to save this aircraft from a fire or other serious mechanical issue. Capt. Zaharie Ahmad Shah was a hero struggling with an impossible situation trying to get that plane to Langkawi. There is no doubt in my mind. That’s the reason for the turn and direct route. A hijacking would not have made that deliberate left turn with a direct heading for Langkawi. It probably would have weaved around a bit until the hijackers decided where they were taking it.
Surprisingly, none of the reporters, officials, or other pilots interviewed have looked at this from the pilot’s viewpoint: If something went wrong, where would he go? Thanks to Google Earth I spotted Langkawi in about 30 seconds, zoomed in and saw how long the runway was and I just instinctively knew this pilot knew this airport. He had probably flown there many times.
Fire in an aircraft demands one thing: Get the machine on the ground as soon as possible. There are two well-remembered experiences in my memory. The AirCanada DC9 which landed, I believe, in Columbus, Ohio in the 1980s. That pilot delayed descent and bypassed several airports. He didn’t instinctively know the closest airports. He got it on the ground eventually, but lost 30-odd souls. The 1998 crash of Swissair DC-10 off Nova Scotia was another example of heroic pilots. They were 15 minutes out of Halifax but the fire overcame them and they had to ditch in the ocean. They simply ran out of time. That fire incidentally started when the aircraft was about an hour out of Kennedy. Guess what? The transponders and communications were shut off as they pulled the busses.
Get on Google Earth and type in Pulau Langkawi and then look at it in relation to the radar track heading. Two plus two equals four. For me, that is the simple explanation why it turned and headed in that direction. Smart pilot. He just didn’t have the time.
Chris Goodfellow has 20 years experience as a Canadian Class-1 instrumented-rated pilot for multi-engine planes. His theory on what happened to MH370 first appeared on Google+. We’ve copyedited it with his permission.
mbonwick
26 Oct 2006
Kendal
Although as has been pointed out, the standard checklist for a fire does not tell you to pull any breakers associated with the transponder etc. Nor does that theory explain the changes of course so late on in the flight.
Yew
12 Mar 2011
Anyone remember the plot of the Ian Fleming novel Thunderball...
CC 72100
23 Jan 2012
Re. SwissAir 111 - I thought it was concluded that the pilots had been overcome by smoke by then? At least all flight systems had gone by then, and the co-pilot showed signs of being dead when the plane hit the water?
It's certainly the first time I've heard the pilots in that accident being described as 'heroic'. They didn't do much wrong, they were faced with the impossible, but they were very much overcome by the situation and didn't recognise the gravity of it soon enough.
Unless Air Crash Investigation lies, of course...
richw
10 Jun 2010
Liskeard
A statement by Malaysian PM Najib Razak has just been released. I understand its middle of the night out there for this breaking press conference to be released.
"This evening I was briefed by representatives from the UK Air Accidents Investigation Branch (AAIB). They informed me that Inmarsat, the UK company that provided the satellite data which indicated the northern and southern corridors, has been performing further calculations on the data. Using a type of analysis never before used in an investigation of this sort, they have been able to shed more light on MH370's flight path.
Based on their new analysis, Inmarsat and the AAIB have concluded that MH370 flew along the southern corridor, and that its last position was in the middle of the Indian Ocean, west of Perth.
This is a remote location, far from any possible landing sites. It is therefore with deep sadness and regret that I must inform you that, according to this new data, flight MH370 ended in the southern Indian Ocean.
We will be holding a press conference tomorrow with further details
Zoidberg
27 Aug 2010
West Midlands
Kuala Lumpur is eight hours ahead of GMT, so when you posted it'd have been 2225hrs.
Just wish they'd retrieve something and be able to say it is part of/came from the aircraft.
Tim R-T-C
23 May 2011
Very sad news, although at least it will give the families some closure and hopefully it means that the debris spotted in the south will be those of the aircraft.
Class172
Quizmaster
20 Mar 2011
West Country
I have to agree, very sad - I was hoping of the unlikely event that it may have crashed over land, in stead of it being in the middle of the ocean on the way to Antarctica.
kylemore
28 Aug 2010
Am I just being stupid in wondering how they had enough fuel to get way down there?
Tim R-T-C
23 May 2011
I would still consider suicide-by-pilot to be the most likely explanation given the evidence we have - after killing the other crew-member in the cockpit, the pilot could have deliberately turned off the comms and setting a route in the autopilot to take the plane to the most remote location in the hope that it would never be found.
I would suggest that it was not a 'suicide terrorist' attack or it is more likely the plane would have been crashed into land to be found quicker and a martyr video made and left at the pilot's home.
It being night at the time and with the turns detected on the radar being quite gentle autopilot controlled ones, passengers and crew on-board might simply not have noticed.
richw
10 Jun 2010
Liskeard
It had 6 hours of fuel plus with the right winds would glide for another 2 hours at normal flying altitude plus whatever time it takes to glide down from 30000 feet, so in reality the area they have found debris is the realistic area it could have made at those timings.
jon0844
1 Feb 2009
I would still consider suicide-by-pilot to be the most likely explanation given the evidence we have.
Surely you'd take control and crash it as soon as possible?
And I am not sure what evidence we actually do have? We now know where we think it crashed, but the amazing work by Inmarsat can't give any other clues as to what happened.
Tim R-T-C
23 May 2011
It could have been someone wanting, for personal reasons, to commit suicide by simply disappearing.
The evidence we have is of the course adjustments made to the plane after the transponder stopped, as detected by the military radar. These were numerous enough to suggest deliberate course adjustments and probably rule out the 'easy answer' theory of the crew being killed by a fire that knocked out the comms equipment.
andythebrave
8 Oct 2009
England
Glide around 25 to 30 minutes if the airspeed is just right and you're starting from c. 35k feet. Wind speed has no effect at all.
Tetchytyke
12 Sep 2013
Isle of Man
I don't know, I think what happened to this plane sounds very similar to what happened to Japan Airlines 123 back in the 80s. In that case the hydraulics failed and it glided around for nearly an hour before crashing into a mountain.
Johnuk123
19 Mar 2012
Malaya is now saying they know it's gone down in the Indian Ocean by using "calculations never before used" with no physical proof at all.
Nobody surely still thinks the truth is being told, The Chinese certainly don't.
I think the Malaysians have lied from day one, I think they know full well what happened and why.
What that is of course is very open for debate but one thing's certain it looks very likely that it was well planned.
Tim R-T-C
23 May 2011
But in that case the pilots were able to radio distress as soon as it happened. In this case they disabled the electronics, flew a lengthy detour route and then flew for several more hours before the plane crashed. Not really normal emergency protocol.
YorkshireBear
23 Jul 2010
For a life insurance pay out he would need the plane not to be found hence flying as far south as he did. But I still think that is unlikely to be honest.
Johnuk123
19 Mar 2012
It was said the other day that he had no substantial life insurance, and if he did they would never pay out as there are too many things that can't be confirmed.
The Chinese are now demanding that Malaya gives them concrete satellite proof that it was even in that area at all.
ralphchadkirk
20 Oct 2008
Essex
We still don't know whether the transponder was deliberately turned off or not. We know it went off, but not how.
