trackside7
Posting this as I’m keen to know if there’s a better way to make PAs from the cab (non-driver).
The method on the 377/387 involves holding down the yellow ‘PA’ button and the push to talk button on the handset - at the same time. This seems rather silly, as the cab to cab button doesn’t need to be held down, but the PA button does.
Out of the cab, making announcements from the steward’s panel only requires the PA button to be pressed on the handset once, then push to talk accordingly.
1. Is there a better way to free up one hand when making announcements in the cab?
2. If there is a driver key present, does this omit the need to hold down the yellow ‘PA’ button?
