The cheapest solution to the CET issue is just to lock out all the toilets.
Not really a workable solution for InterCity use.
How will the 2020 regs affect heritage operations (on NR or on preserved lines)
I see your point but its still a cheaper option than new stock for open access operators that want to join the marketAs already mentioned (twice?) in this thread, the Chiltern type doors cost a fortune
.I like the idea of that. I am surprised that BR didn't go for this design or the sliding plug doors similar to what Ireland did in the 1980's. But on reflection though, common sense and patience was prevalant at the time the HST's and Mk3's were built. The main reason why central locking was added to the Mk3's was due to impatient people trying to board the HST when it was departing the station or opening the doors when it was still moving into the station. Which has resulted in some people falling from the train when it was moving!Yes, I believe talk is indeed of sliding rather than plug doors, these are said to be cheaper. The Mk3 design has the advantage of having blank space next to the doors (luggage rack/bog space) into which they can retract without blocking windows.
Do you think that is a good idea to ride on a long haul service with no toilets on them? :roll:.The cheapest solution to the CET issue is just to lock out all the toilets.
I am surprised that BR didn't go for this design or the sliding plug doors similar to what Ireland did in the 1980's. But on reflection though, common sense and patience was prevalant at the time the HST's and Mk3's were built. The main reason why central locking was added to the Mk3's was due to impatient people trying to board the HST when it was departing the station or opening the doors when it was still moving into the station. Which has resulted in some people falling from the train when it was moving!.
It's a shame Auto closers (common on the continent) could not have been included, however. I feel they would have helped dwell times.
I see your point but its still a cheaper option than new stock for open access operators that want to join the market.
New rolling stock is not the only alternative - there are a number of options available well documented previously on this thread.
Hasn't anyone heard I thought the deadline has been extended to the 1st April 2023.
so slam doors could potentially continue until then.
Yes I did.Did you read that pearl in a rail magazine?![]()
Yes I did.
You don't need an underframe. The sectional design could be built as a series of monocoques bonded together. I believe the Mk4 is designed that way. Or could be welded to a steel floor as the 153/155 fleet areI don't know whether you are joking - but the Mk 3 is a monocoque. What underframe would you use?
The toilets can be dealt with. Accessible toilets are modular, there is only one required in the train, so lock out one door, replace the droplight with a stuck in piece of obscure glass, You then have one less exit, but space for an accessible toilet using the existing toilet space and one side of a vestibule.
