Making a GSM-R DCP functional
20 Sep 2023
GTR Network
Hello, I own one of the GSM-R DCP & Phone sets from 507010. I want to make it be able to display text on the screen and register inputs from the buttons on my computer. How would I go about this?
20 Feb 2025
It looks display you have is simply a head unit that connects to the main transceiver, which is housed elsewhere on the train. I'm not sure if can work without it. This may be of some help?
crablab
8 Feb 2020
I mean, probably yes.
Posting the other side to show the interface between the head unit and transceiver would be helpful.
It'll be difficult to reverse engineer the communication between the two without both halves, but probably not impossible. It's not something that'll be quick and it might be destructive.
20 Feb 2025
The best bet might be getting in touch with a local amateur radio club, there would certainly be someone who could advise or give hands on help.
20 Sep 2023
GTR Network
My main goal would probably be to get it to connect to my computer and simulate just the actions you can perform on the DCP (e.g registration)
I hope I can do it in a way that doesn't permanently break or damage it.
crablab
8 Feb 2020
Sure; or a local hackspace. It needs someone with a logic analyzer who knows about electronics and has some time to spare. Alternatively, the OP could perhaps start researching the topic and give it a go themselves :) They may well be in range of a hackspace with useful equipment and people with knowledge who can give advice.
Sometimes physical disassembly is a necessity (to remove and dump any microcontrollers), especially if there isn't a working setup to reverse. You may have to accept that one needs to be sacrificed (at least visibly) to understand how the device works and write software to emulate whatever it's designed to talk to.
I think that's quite an ambitious goal! :)
Fragezeichnen
14 Jun 2021
Somewhere
Sorry, but this is not good advice.
The internal connection between a display unit and the radio itself has nothing do with radio at all, and an amateur radio club would be of no assistance. It would be like asking a TV aerial installer to fix your TV remote.
As mentioned this is merely a display unit and does not "know" anything about it's original purpose. To figure out the manufacturers proprietary internal communications would be a very difficult task requiring considerable time and skill.
The only realistic option is to remove the internal electronics and connect the buttons and display directly to your own microcontroller. This might involve replacing the display with an equivalent of the same size if you are unable to identify or find documentation for the existing one, or cannot source a display controller.
20 Feb 2025
I think you have misunderstood what an amateur radio user does. It's much more than simply installing an antenna.
It's common to modify radios including the Philips FM1000 which was used in trains prior to GMSR for use on amateur radio frequencies.
Here is a discussion about amateurs modifying the Philips FM1000. It might be helpful?
