Magstripe one day travelcards
barringtoncem
12 Jan 2020
Papworth Everard
Just wondering the next time i have to purchase this type of ticket would it be better to use contactless as the magstripe seems to fail easily as i have been stuck at a unmanned tfl
station with no staff to assist
Hadders
27 Apr 2011
It depends on what journeys you're planning to make and whether you have a railcard.
If you can tell us more about your plans we can advise.
Hadders
27 Apr 2011
Get yourself a TOC Smartcard, much more reliable to have a One Day Travelcard on.
Agreed, but I still wait for the time when I can purchase a Stevenage to London Zones 1-6 Super Off Peak Travelcard on a smartcard!
Flying Snail
12 Dec 2006
If only there was a TOC smartcard that made it easy to buy tickets from various retailers online.
Considering that RDG want rid of magstripe CCST tickets and TfL do not want to entertain e-tickets it seems that a rather obvious solution would be to replace CCST for travelcards and other cross-London tickets with tickets fulfilled to re-usable smartcards (or even single use smartcards) but I'm not a rail industry insider so what do I know?
CyrusWuff
20 May 2013
One issue with that is that Zones 7-9 are currently fudged in rail industry systems by using a route code rather than as location codes like other zonal combinations are. As such, presumably a Travelcard with validity in Zones 7-9 that's loaded onto a Smartcard is likely to be interpreted by LU gatelines as only being valid to Zone 6.
Edvid
7 Feb 2008
Considering that [...] TfL do not want to entertain e-tickets
A recent trial with handheld barcode readers at certain NR/LU interchanges says otherwise.
In the long term they'll also be involved in the RDG-led project to create "Barcode 2.0" for (non-Travelcard?) cross-London tickets.
jfollows
26 Feb 2011
Wilmslow
I’ve never had a magstripe ticket failure, so it may be because of the way you save your tickets, just a thought.
Hadders
27 Apr 2011
Railcard discounted CCST tickets never work the barriers at Stevenage station so I suspect the same set up is in place at Huntingdon.
Where else is the tickeyt not working the barriers?
