Macclesfield to Holyhead via Stafford
RailAleFan
2 Jul 2014
Midlands
Is this is a permitted route? 1 change, CrossCountry > Avanti
I'm not getting anywhere with journey planners, insisting on routing via Kidsgrove and Crewe.
NRE brings up the result based on timing but with no tickets available.
Cheers!
Unfortunately not a valid route. The valid routes are via Stockport and Crewe/Altrincham, or via Kidsgrove/Stoke and Crewe.
It would make sense for it to be a permitted route since it's the only one-change option, but that's not how the Routeing Guide works!
If NRE won't return a through fare, that's generally because it's a journey that doesn't follow a permitted route.
Mcr Warrior
8 Jan 2009
The Macclesfield to Crewe leg is something like 22 miles if interchanging at Kidsgrove. More like 60 miles via Stafford.
390136
28 Jan 2019
If you're looking to avoid Kidsgrove and/or more than one change, I would highly recommend starting your journey from Wilmslow and changing at Crewe.
The up Avanti connects nicely with the Holyhead in most occasions. However you'd need to drive / get a lift as it's a 20 min drive between the two stations.
Fawkes Cat
8 May 2017
It's always open to the OP to buy separate Macclesfield to Stafford and Stafford to Holyhead tickets if limiting to only a single change is the important thing.
jfollows
26 Feb 2011
Wilmslow
Or the 130 bus service.
The forum's site will do this seamlessly; you could specify maximum one change to achieve this, or specify via Stafford as a via point.
We will issue all tickets in one handy PDF and seat selection is also possible on both services.
RailAleFan
2 Jul 2014
Midlands
Thanks for the replies.
This just hadn't occurred to me as an option, and we'll be on the right side of Macclesfield for that too. Taxi ~£20 so when the time comes that's what we'll do...
Cheers
390136
28 Jan 2019
Cheers
Yeah I thought it was 50/50 but always worth a shout for sure. Glad I could help
I did wonder if there was a bus but couldn’t find it, thank you.
