Macclesfield line closed!
CosherB
23 Feb 2007
Northwich
A bus driver has tried to squeeze a double decker under the railway bridge in Macc, so all trains cancelled (and roads closed!).
Whistler40145
30 Apr 2010
Lancashire
Well, he was a bright spark!
Either he didn't notice/read the Sign with it's height or he was a novice driver or new to that route?
Are services being diverted from Kidsgrove to Crewe or Norton Bridge & direct to Crewe?
142094
7 Nov 2009
Newcastle
No doubt it will be referred to as a "railway accident" or something similar in the press.
About time some sort of law was introduced whereby the driver is punished for doing something as stupid as that, and the company has to reimburse TOCs for the disruption caused, along with compensation to Network Rail fro the damage. I appreciate that it is human error but at the same time if you are driving a bus/lorry which is tall/wide etc then IMO it is dangerous driving if you don't pay attention to the road signs. One day there will be a big accident where people will be seriously injured and/or killed, no doubt that will be when things change (which is unfortunate).
sonic2009
19 Jan 2010
Crewe
i think trains are being diverted saw an arriva xc at crewe stopped to drop off. and left for manchester piccadilly... around 1900
mumrar
26 Sep 2008
Redditch
It amazes me just how many of these occur, but sometimes it isn't the drivers fault. Recently a bridge near Chepstow was struck and damaged badly by a lorry. The line closed for around 6 hours, but the lorry had been under Police escort at the time.
Ivo
8 Jan 2010
Bath (or Southend)
What is the bridge limit at Macc?
This is part of the problem with "high-roof" double deckers. Obviously they are higher, and are therefore less likely to squeeze under railway bridges. Here, there is a 13'3" bridge over Lower Oldfield Park, so only single-deck buses are allowed on the route (annoying given it serves the two Universities). On the other hand, the Southend area has plenty of ~14" bridges, including a 13'6" at Hockley, and still Arriva double-deckers (the few that still run in Southend :( ) can run because they are all so low. So why can't other areas follow the same example? Why do they need to be 14'3"?
For the record, I believe the maximum standard height for a decker is 14'9", and the lowest standard height for a decker is 13'8".
This is precisely what happens.
1) Assuming there is enough evidence, the driver will be prosecuted for (at least) driving without due care and attention
2) Network Rail will go after the driver's insurers, to claim the cost of a) damage to the infrastructure, b) penalty payments to the TOCs for train delays, c) any consequential costs and d) the costs of pursuing the claim. Usually they are successful.
Whistler40145
30 Apr 2010
Lancashire
Does Network Rail have any authority over the types of vehicle that can travel under Railway Bridges with regards to the height & width of the vehicle?
Minilad
26 Feb 2011
Anywhere B link goes
A couple of months ago I was on a Reading train and was cautioned for a bridge bash just south of Fenny Compton. I passed over the bridge at 5mph as instructed and began to power up. I had got up to about 40 and rounded a bend to see a PW man waving like mad at me. I stopped about 15 foot short of a bridge just as a Chiltern 168 also came to a stand. So there we are either side of this bridge. The PW way explained that the bridge had a 4 ton weight limit and a muppet in a 38 ton truck had tried to drive over it and got stuck !!. The police were also there and they told us a list of the offences the driver would be done for, ran to about 6 or 7 as I recall. We sat there for nearly 2 hours while the bridge was examined. We made sure the passengers on board were well aware why we were stuck !!
CosherB
23 Feb 2007
Northwich
I am very pleased to hear this. Another advantage of the privatised railway - any private company that suffers loss at the hands of a third party will go after that party for recompense.
No*, this is covered by highway regulations, although the height / width may be spcified by Network Rail.
* Exception is for private road bridges, known as Accommodation bridges. Often there is a legal agreement between Network Rail and the owner of the rights to the private road, and this can specify height and width. For overbridges it can also specify weight limits.
CliveJones
17 Feb 2011
I saw a picture of a bridge in america and it had a sign a short distance before hand. It was metal and the same clearance with the words "If you hit this sign you WILL hit that bridge".
Not saying its going to stop all the fools, but I wounder if they make a difference (relatively cheap to install I expect)
142094
7 Nov 2009
Newcastle
In some places there are sensors which work I think with an Infra red beam. If the beam is broken, such as by a high sided vehicle, a sign up ahead illumiantes telling them to turn around (has to be placed far enough back to alow something to turn around, which could be a few metres to a few hundred yards away from the bridge).
I think this is only in places where there has been repeated bridge strikes. Certainly trying to install it for every bridge in the UK wouldn't be feasible.
t o m
7 Feb 2011
There's one of those in Kettering for the bridge near the station, I used to pass it on the school bus, not sure if it's still there though.
On BBC Travel News it says there are 45min delays between Westbury and Bath Spa due to a vehicle hitting a bridge.
Dreadnought
1 Oct 2007
Not just the privatised railways as this also happened when it was BR.
CosherB
23 Feb 2007
Northwich
No TOC penalties to reclaim from the errant driver in those days, though - and in the nationalised industry far more difficult to legally identify direct costs from the incident to go after the driver for.
northwichcat
23 Jan 2009
Northwich
Some at Arriva control decided to give the driver a double decker to run a single decker route.
How much blame lies with the driver depends on:
1. Whether the height limit on the bridge is clearly signposted.
2. Whether the height limit is accurate. Cheshire East, like other councils have gone for a cheap approach to repair worn out road by putting new tarmac over the old. This could make a 3.6m bridge become a 3.5m bridge.
185
29 Aug 2010
The Arriva bus came to a halt outside a shop called S&M SUPPLIES :)
Roll on the 'topless' jokes :roll:
Whistler40145
30 Apr 2010
Lancashire
Why was the Arriva Driver given a Double Decker for a Single Decker route? Was he new to the job or route?
Also, shouldn't the Driver have questioned the type of Bus provided?
Surely, the Depot staff have a list of routes that Double Decker buses were permitted to run on?
Dreadnought
1 Oct 2007
As in BR days it was a regionalised network there would be no TOC penalties!
From my time on the LM region I am sure that the individuals / companies (or their insurance companies) that caused bridge strikes were charged for the cost of the bridge examination, a charge per delay minutes caused and any repairs that were necessary as a result of them striking the bridge.
IanXC
Emeritus Moderator
18 Dec 2009
Have to love the irony of the view of the (Arriva) bus with the cancelled Arriva Crosscountry train in the background. I bet theres some cringing going on at that in Sunderland!!
CosherB
23 Feb 2007
Northwich
That was one of the last Leyland Olympians in the area :(
Well, the sun has been shining recently (even in Macc), and what with global warming and all, there's a growing need for open-top buses!
That Olympian might be around for years yet! Open-top tour of the Peak District, anyone? :D
