Luton to Manchester
MrCub
23 May 2009
SE England
Hello there
Advice please, including the use of split tickets if appropriate, for Luton to Manchester return, going on Friday Nov 5th returning on Sunday 8th Nov. Current price online is £175 - I don't want to pay that!
Help appreciated
Mr Cub
hairyhandedfool
14 Apr 2008
It really depends when you are travelling on those days, I would presume leaving Luton at peak time, so here is my thought.
Luton to Manchester Rte Chesterfield is £162 Anytime Return
Luton to Leicester Rte Not London Anytime Return is £73
Leicester to Manchester Anytime Return is £55
Leicester to Manchester Off Peak Return (after 0900) is £38.50
So potentially even this simple split (most Northbound EMT trains call at Leicester) could cut your bill to £111.50. It is only valid via Leicester and changing once at Sheffield could extend your journey by 30 minutes or more over the route via London. It also gives you the option of changing at Leicester for Birmingham and then up the West Coast although it may lengthen your journey further. Spliting tickets again at Sheffield may take a couple of pounds off the open fare but restricts you to going that way.
HTH
MCR247
7 Nov 2008
Luton 1015 - MKC 1100 Virgin Bus
MKC 1150 - Manchester Pic 1328 Virgin Train
£28.05 Off Peak singles, I can only find this on EMT, on NXEC it gives me the advance at £35
Manchester 1315 - MKC 1449 Virgin Train
MKC 1520 - Luton 1605 Virgin Bus
£28.05 Off Peak Singles. NXEC website wants £55.10 coming back
EMT Website
This only works if you can get to & from STP for these times
STP - SHF
0637 - 0904 £13 using EMTs best fare finder
SHF - MAN
0911 - 1002 £5.50 Advance single **If you missed this connection you'd have to pay £15.30 for an anytime
MAN - SHF
1342 - 1435 £4.00 advance
or
MAN - SHF
1420 - 1508 £6 advance
SHF - STP
1527- 1903 £13 standard or £19 first
Totals
£35.50 getting first option from MAN and standard from SHF
£37.50 getting second option from MAN & standard from SHF
£41.50 getting first option from MAN and first class from SHF
£43.50 getting second option from MAN and First Class from SHF
I hope this helps :)
Found using EMT website
